Can i tow this 200 miles? pic inside
#41
I used my 92 xcab to pull a 12 foot Uhaul trailer all the way across the country a few years ago. Was totally fine, but a) was damn careful, and b) the truck bed was filled with stuff, adding a lot of weight. Up the rockies (verrrrryyyyy slow) and down the other side no problem. Sure as hell wouldn't do it again, as it was exhausting ... not least because of the whining, drugged out cat in the back seat.
For 200 miles of flat terrain, you're fine. Just a) go slow, b) put weight in the back of the truck, and c) don't do it if it's windy out.
#43
i tow one 4runner with my hilux "4runner" with a small turbo diesel..
that is the biggest load i would ever tow.. and i still have lots of spool left in er but it just wouldnt be safe.. which was also a main reason besides the solid axle i went down to a suzuki play rig..
id rent a truck or pay someone to tow it... or ask someone to use there 1 ton... dont know any landscapers?
#44
doesn't anyone bother to read a thread anymore or do they just jump at the chance to post a response
the OP posted this the first week of may
ok thanks guys , i came to my senses, I am not going to tow or buy the boat. I am looking for a smaller bowrider now so i can do watersports. I could probably borrow a better tow vehicle but then i still have to go to the ramp and back every time i go out and this big of a boat is too much hassle... I was considering this boat basically as a party boat to take out on the lake. I am now on the look again lol
#45
I agree if you had a trailer controller. Hit that and the trailer will straighten out. In the absence of a controller, all you have is the trailer brakes.
I guess my assumption is that most people inspect the trailer, get the surge brakes to engage...etc.
That trailer is pretty heavy, without a payload. Add in some books into the nose and your done.
Getting on the brakes if you get swing works-with this type of trailer (and the brakes work). I can't say exactly why, but it does.
btw : have fun towing your 2600lbs trailer of your motocarier
#46
you have to seriously stop giving people trailering advice. even with a surge brake you do not stomp on the brakes!! pull the e-brake (not hard) so its just your rear braking that will activate the surge brakes and stop the trailer from swaying.
Me
Wrong.
I had that trailer and that situation. Go ahead and pull the ebrake at 60 MPH. Wait for the brake pads to glaze over in about two seconds while the trailer is swinging even more wildly.
Then while your rear brakes are now shot, then try to slow down.
Go ahead.
Send pictures.
#47
I tow my brothers Bass Tracker boat (less than 2,000 pounds) and my 99 Limited hates it.
I love my 4Runner , but it's not a tow vehicle. THere's no way I would tow the boat in the picture with a 3rd gen 4Runner.
My 2 cents.
My 2 cents.
#48
Prove
Me
Wrong.
I had that trailer and that situation. Go ahead and pull the ebrake at 60 miles per hour. Wait for the brake pads to glaze over in about two seconds while the trailer is swinging even more wildly.
Go ahead.
Send pictures.
Me
Wrong.
Go ahead.
Send pictures.
btw if you can glaze over your e-brake in about two secconds you need to get some better pads.
#49
Wow...you guys ever pulled the ebrake on your car before? You do 180 degree turn quick...real quick. I wouldn't EVER EVER EVER pull my ebrake without a trailer, let alone with a loaded trailer or boat, etc. You're asking to die.
#51
Hey guys!!
Did you read this guys post?? He decided NOT to buy the boat so he's not going to tow it neither!! Totally gr8, 23 posts after he posts the above declaration "I came to my senses" I think its a moot point, but at least he came here to get "educated" by our sterling panel of experts! I love Yota Tech!
#53
#54
I put a tranny cooler on my brothers runner in like 15 min you spice it into existing lines and for time sake you ziptie it up and add more fluid should not take long. You could tow it fine if it has surge brakes which it should and you go SLOW SLOW SLOW SLOW SLOW SLOW SLOW get the picture.
crashburnoveride
Jul 10, 2015 06:39 AM
