Can I have manual hubs on a 4R with ADD?
Old Jan 13, 2004 | 10:37 PM
Los Gatos?'s Avatar
Can anyone point me in the direction of finding out how to get manual hubs on my ADD "equipped" 4Runner? I'd really like to
reduce wear and increase mileage (every mpg counts!)
Old Jan 13, 2004 | 11:30 PM
toy283's Avatar
Sure you can. Just find a set of manual hubs from any '96-'94 IFS truck or 4Runner and bolt them up. You cannot use the hubs from '79-'85 solid axles as the spline count is different. You may also need to get the hub nuts (two each side) and lockwasher from the dealer, but those usually aren't too expensive.
Be aware that any shift-on-the-fly capabilities you have will be inoperative unless the hubs are locked.
Toyota p/n's:
Locknut: 43521-60011
Washer: 90215-42025
Gasket: 43422-60020
Old Jan 13, 2004 | 11:37 PM
tenfourtyeight's Avatar
Kind-of a hijack- Is there anything wrong with leaving your manual hubs locked all of the time, druing daily driving? Just curious as to what effect it would have.
Old Jan 13, 2004 | 11:50 PM
toy283's Avatar
No different than having ADD. I wouldn't worry about it, I don't.
Old Jan 13, 2004 | 11:55 PM
Sweet, cause I have random moments when I'll see something I'd like to drive over, and I need to be in 4wd, cause my tires are balder than . The owners manual says to drive 10 miles a month with them locked to make sure everything is lubed.
Old Jan 14, 2004 | 06:41 AM
Brendan's Avatar
You'll probably notice a small vibration in front which is normal.
Old Jan 14, 2004 | 07:07 AM
Glenn's Avatar
Re: Can I have manual hubs on a 4R with ADD?
Yes, you can simply swap the manual hubs in. But I think the best way is to swap out the axle shaft that has the sliding collar. That way you don't have any ADD components on the axle. However, this is a LOT more work.
Old Jan 14, 2004 | 07:10 AM
Glenn's Avatar
No, nothing really wrong with it. I have not unlocked my hubs for over a week, but that is because we got dumped on by a snowstorm. I wouldn't leave the hubs locked all year round though, because it is an unnecessary drag on the engine.
Old Jan 14, 2004 | 01:49 PM
KevyWevy's Avatar
here is a nice little write up here on yotatech.
https://www.yotatech.com/~corey/tech...etal22lica.htm
there are also some good ones on 4x4wire.com i used about 3 different write ups that i found to do mine.
89fourrunner
Feb 17, 2016 06:52 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
stanz
Oct 30, 2015 10:33 AM
Flying91
Sep 10, 2015 03:41 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
