Can I fit a 99+ Grill in my 97?
Old May 17, 2004 | 08:14 AM
BASSMAN's Avatar
Question Can I fit a 99+ Grill in my 97?
Whatsup Guys-
I am going to be installing my tranny cooler this week and I know I have to take off my grill to mount the unit. Does anyone know if I can retrofit a newer style 3rd gen grill in my 97?? If yes, are there any writeups?
Thanks
Old May 17, 2004 | 08:22 AM
4RunnerFever's Avatar
Should be a direct replacement for the grill. There is a tranny write-up on tech section
Old May 17, 2004 | 09:04 AM
li_runner's Avatar
Talking
Yes, the grill will fit, I myself have a 99' grill that I painted to match the color of my 97'. It is basically plug and play. Really no write up needed. The only complicated part is being very carefull when removing the grill you have on now, the plastic tabs will have a tendency to break if forced hard enough. But since you are replacing it, that shouldn't be a big concern. All that is needed is a flat head screwdriver to remove it.
The only thing that may be a concern is the emblem, the older grill's style emblem does not directly fit into the newer grills. I can look at mine again if needed, I forget right now if I replaced the emblem or if I just made the old one work with a dremel tool.
Cheers
Old May 17, 2004 | 09:19 AM
Bob_98SR5's Avatar
Bassman,
Ditto to all of the above. Instead of buying a new 99 grill, post a "Trade" ad in the Classified section and you might be able to find someone to swap a 99 or 00 grill for your 97 grill.
Bob
Old May 17, 2004 | 09:28 AM
shiftMX's Avatar
i'd be interested if your 97 grill is gray, not the chrome type
Old May 17, 2004 | 09:40 AM
BASSMAN's Avatar
Thanks a lot guys, that's nice that i can just drop it in- the 99 grill looks super nice!
Old May 17, 2004 | 09:41 AM
BASSMAN's Avatar
My grill is all grey yes, what is your grill - all crome??
Old May 17, 2004 | 09:57 AM
BASSMAN's Avatar
Exclamation
Cheers
Thanks for the info li. I am totally clueless so forgive me for my stupidity (I haven't gotten in there and or removed the grill yet):
So does the 99 grill come with the emblem or is it just a space that wraps around my existing emblem??
Old May 17, 2004 | 10:24 AM
li_runner's Avatar
Post
Depends on what your plan is.
If you were to buy one from Toyota, no the emblem does not come with the grill. The grill itself is just the bare plastic and their is a space in the middle for inserting a emblem into the grill (since their are different emblem options), and the emblem screws into the plastic grill from the back. You would have to purchase an emblem as well as the grill with this plan.
If you get one used as Bob has mentioned, it would probably come with one. Since the emblems are not universally plug and play like the grill's are a person who would get rid of one would most likely also let it go with the emblem. They are the same size but the emblem has different mounting points with the different grills.
Unless you get a chrome or grey grill (not sure grey is even possible), you will also have to paint it. Which is pretty easy too.
Old May 17, 2004 | 10:53 AM
BASSMAN's Avatar
Correction- My Grill Is Not All Grey- It Has A Crome Piece On The Top And Bottom.
Old May 17, 2004 | 10:55 AM
BASSMAN's Avatar
THIS PAGE HAS SOME GRILLS FOR SALE, LET ME KNOW IF THIS DOESN'T WORK
http://www.speedyautoparts.com/cgi-b...O4RUNNER7.html
Old May 17, 2004 | 11:14 AM
Vato Loco's Avatar
Old May 17, 2004 | 12:37 PM
BASSMAN's Avatar
Vato-
Nice Grill Man. Did You Have To Cut Out Your Old Logo To Mesh It Up??
Old May 17, 2004 | 09:18 PM
User 051420's Avatar
Email this guy: browns@cooltruckparts.com . He can get you a 2001+ grille for $88.50!!! Or so he told me at least. The all black one is cheaper.
1uzRunner
63
Nov 10, 2018 03:58 PM
chuckd83
Sep 14, 2015 03:20 PM
ac7822
Sep 12, 2015 06:57 PM
anniesball
Sep 5, 2015 08:45 AM
