calling about new diffs today - double check specs
Old Aug 26, 2003 | 05:27 AM
jacksonpt's Avatar
Senior Member
I'm going to call Randy's Ring and Pinion today for a quote on new diffs for my rig. Just to double check before I call, the rear is a 8", right? The front is the V6 IFS, right? Isn't the rear reverse cut?
What is a hi-pinion diff? Anything else I should know before I call?
BTW... getting a quote for 4.56s and ARBs front and rear.
Old Aug 26, 2003 | 06:41 AM
TStango's Avatar
I'm curious about how much that would be too. ARB in the front too? I guess you plan on doing it right the first time.
Old Aug 26, 2003 | 06:59 AM
sschaefer3's Avatar
Front 7.5" Tacoma/Tundra reverse cut.
Rear 8" V6
I wouold go with 4.88's and step up to 33's. You will someday anyway. Re-Gear once and plan for the future. You will not be able to tell the difference between 4.56 and 4.88 anyway. With the Auto, 33's and 4.88 it will be sweet.
I have driven to Colorado twice and to fresno with 5.29's and everything is just fine. 4.88's are your friend.
Also the Off Road Solutions kit not only gives you manual hubs but heat treated stronger outter CV's and center shafts. I spent a few day with the ORS guys and I asked them all the details of the Manual hub kit.
Also with 5.29's I can go to 35's next time. And I will. 315/75/16.
Old Aug 26, 2003 | 07:02 AM
jacksonpt's Avatar
Senior Member
Rear 8" V6
That's what I thought, thanks. Because the front is reverse cut, is it necessarily a hi-pinion?
Old Aug 26, 2003 | 07:19 AM
sschaefer3's Avatar
Well, yeah soft of, but it's not really the same. You want to be sure to specify that you have a 4Runner with ADD.
Karlton has a front 2001 Tacoma diff he as been trying to sell for over a year. Should be the same, but remember one was made in America and the other in Japan. Probably different suppliers.
Mark G. has both a 2000 4Runner and 2001 Tacoma, he may be able to better say if the 2 diffs are the same.
Old Aug 26, 2003 | 07:22 AM
sschaefer3's Avatar
Also remember you can't drive it with the alxes out. With the ORS kit you can. Mark G. also has a set of "cut off" axles you can run with the diff out. Since I have met you and know your a good guy, I can refer you, pay shipping both ways and he might loan them to you.
Old Aug 26, 2003 | 07:36 AM
jacksonpt's Avatar
Senior Member
Just got off the phone with Randy's...
$1763 (no core charge) for the rear - that's 4.56s and an ARB
$1329 +$216 core for the front - again, 4.56s and an ARB
I knew it was goign to be expensive, but that's more than I was thinking.
Old Aug 26, 2003 | 08:13 AM
sschaefer3's Avatar
For lockers and gears that's right on. Huge transformation of the vehicle though. It's the parts you CAN'T see that really matter off road.
Old Aug 26, 2003 | 08:15 AM
sschaefer3's Avatar
Here's a comparison:
Rear ARB RD08 and Compressor $800
Install with new axle seals, axle bearings, carrier bearings & gaskets $735
This was keeping the stock ring and pinon.
See why I saw 4.88's plan for the future.
Old Aug 26, 2003 | 08:17 AM
sschaefer3's Avatar
You can then sell your stock 3rd on eBay.
Old Aug 26, 2003 | 03:39 PM
Bighead's Avatar
Jackson: is the price for the rear with or without the ARB compressor? Did you happen to ask them about 4.88s?
Inchworm has a rear 3rd with 4.56s and ARB for $1565. The same with 4.88s is $1575. I am going to call Reider Racing sometime and see what kind of prices they have. They might be someplace else for you to check.
Old Aug 26, 2003 | 06:49 PM
jacksonpt's Avatar
Senior Member
No, I didn't think to ask. I've got a couple of other places to get quotes from as well, so we'll see. Post back what you find out and we'll join our research - see who has the best deal.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
