Caliper sticking?
Old Apr 12, 2007 | 08:30 AM
Beartracker's Avatar
Caliper sticking?
What causes calipers to stick and how do you unstick them? My right front is sticking just a little until it gets warm and then it's fine. It kinda sounds like the old drum to the shoe noise but just very , very minor when I press and release the break first thing in the morning. After it warms up the noise is gone.If I pull off the wheel can I spray the caliper with something and if so, what and where? Thanks , Mike
Old Apr 12, 2007 | 08:45 AM
JBSTRD's Avatar
Do you know if your rotors are warped a bit causing them to stick, unstick, stick, etc? You could pull the caliper off and check the pads and rotors to try and narrow down the problem.
Jason
Old Apr 12, 2007 | 08:53 AM
NaeSLaS's Avatar
check the fluid too. Dirty brake fluid was causing my brake caliper on my car to stick. The caliper wouldn't back off.
Old Apr 12, 2007 | 08:59 AM
04 Rocko Taco's Avatar
and if your just bored....rebuild calipers, CLEAN (brake cleaner) and caliper grease all moving parts, and then put on new rotors ()brembo blanks?) and pads and go from there. lol.
Checking through things sounds easier, and less exspensive, but if you wanted to throw parts at it, that'd be the way to go. lol.
Old Apr 12, 2007 | 09:47 AM
Brand new Brembo blank rotors and brand new Hawk pads.About two weeks old. My mechanic put them on but he has the flu or some kind of crud right now. I just thought I could do something to fix it myself and not bother him at this time. He a great mechanic and friend. The fluid is new and the brakes work perfectly. Just have that noise when I get ready to leave in the morning then it's gone.I do know that he put no-seize on the pins. Mike
Old Apr 12, 2007 | 09:50 AM
91TPU's Avatar
my friends 99 tacoma had this issue with the passenger side front caliper, when it was cold, its seemed to drab the pad intermittently, then once it warmed up, it no longer did, and it no longer pulled to the right...had some shop rebuild the caliper and all was well...
Old Apr 12, 2007 | 10:35 AM
Thanks for the info guy's. Guess I'll wait tel my mechanic gets better and let him rebuild it if it needs that. Mike
Old Apr 12, 2007 | 11:54 AM
MTL_4runner's Avatar
I agree, it sounds like you may need to rebuild one of the calipers.
Really not a bad job at all if you take your time and do it right.
Old Apr 12, 2007 | 01:11 PM
VR23's Avatar
Sorry for double-posting this from another thread, but I've had no takers so far and need to get something pretty quick.
I've abandoned my desire to upgrade my brakes via the Tundra route (too many $$ at the moment) and figure this was the most appropriate thread for the following. I have now decided to go with the blank Brembo rotors and new pads for the front. I'm in BC and the cost of these rotors is almost $100 ea. I wanted to go for the Performance Friction Landcruiser pads, but can't find them offerred anywhere. In response, the supplier offerred the following and I'm curious as to what the best route to go is as I know nothing about the first 3 listed;
1)PBR metallic
2)Apex Kevlar
3)Raybestos Ceramic
4)OEM Toyota pads
The Ceramics were the most expensive quoted (~$10 higher than the others)and I don't have a price on the yota pads. I would appreciate any comments from other users who have experiences with any of these.
Old Apr 12, 2007 | 01:26 PM
CJM's Avatar
CJM
Buy your parts off the net, and buy Hawk brand LTS pads..if they can stop my T100 they can stop your trucks well.
Old Apr 12, 2007 | 02:55 PM
The Brembo blank rotors is what I have with the Hawk pads. Best move I ever made on brakes.
Old Apr 12, 2007 | 03:01 PM
Here is where I get most of my parts.
http://replacement.autopartswarehous...20plug%20wires
Old Jul 17, 2007 | 10:34 AM
Bart13's Avatar
Does any one have any info on how to rebuild the front (02 4wd 3.4l V6 tacoma)calipers? Or where I can find it?
Thanks
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
zanzabar0
Oct 11, 2015 02:56 AM
irv
Sep 29, 2015 01:04 PM
user 82300
Sep 15, 2015 05:49 AM
