cabin noise reduction
Old Mar 11, 2003 | 06:12 PM
bldavis11's Avatar
hey folks,
has anyone experimented with dynamat's noise dampening products? i figured that they might be good for folks with tires that generate a lot of road noise. just wondering what everyone though.
http://www.dynamat.com
-davis
Old Mar 11, 2003 | 06:18 PM
Del's Avatar
Del
I personally think it's a waste of money. When I had my car, I wanted to dynomat my trunk to help the rattling stop. The place I said it would be around $300 just for the lid of the trunk. I never though about that stuff again.
Old Mar 11, 2003 | 06:27 PM
bldavis11's Avatar
yeah, it's definitly a bit on the high side. i'm sure there are other companies who aren't as high.
-davis
Old Mar 11, 2003 | 07:40 PM
Bumpin' Yota's Avatar
ill be doing a write up on that directly along with a few other odds and ends.
Dont' mess with dynamat it costs WAY too much for what you get. Instead get hi-temp mastic from www.mcmaster.com. Way cheaper for the same result. I utilized 3 of their big sheets covering my 4 door skins and the rest went on the roof. I also used a total of 12 cans of expanding foam in my yota (I think it will float now...LOL) As far as cutting out road noise the roof was a HUGE help, but if you have pulled up the carpet already notice that toyota did a great job in doing some sound deadening. All you need to add is something to kill the high frequency road noise. So you just add some 8# carpet padding underneath your carpet and in the cargo area.....the results will shock you. Incidentally, at 80mph you can talk very softly and everyone inside will hear you. Ill have to take some db measurements of the current road noise....
Old Mar 11, 2003 | 07:50 PM
Bob_98SR5's Avatar
Bumpin:
Arrrgh! Yet another good mod that I must do!!!! Thanks for the great tips...man, my wallet feels lighter again.
Bob
Old Mar 11, 2003 | 08:01 PM
Del's Avatar
Del
Hey Bumpin,
Would any of that hi-temp mastic help with the insulation as far as heat goes? I go camping in the desert and end up sleeping in my truck cause everyone else snores :pig:
Anyway, it gets damn cold at night out there and last time I forgot a sleeping bag and nearly froze! Thanks.
Old Mar 11, 2003 | 08:05 PM
Originally posted by Del
Hey Bumpin,
It should help a small amount, but I think the biggest thing to help the insulative properties of your rig would be the carpet padding. The more air you can have btwn you and the outside the better.
One problem you may run into with hi temp mastic in the desert is that the door skin and outer skin will get DAMN hot....im not sure if any asphalt based adhesive would stick... try a small amount on a verticle location and see if it stays put in the dester heat after a few days.
Old Mar 11, 2003 | 08:15 PM
Del's Avatar
Del
Cool thanks for the info.
Old Mar 11, 2003 | 08:17 PM
no problem!
Old Mar 12, 2003 | 09:22 AM
bldavis11's Avatar
Bumpin,
I checked out the mcmaster-carr wedsite, and was overwhelmed with the product listings. which type of sound barrier did you employ? They list like 6 pages!
-Ben
Old Mar 12, 2003 | 09:32 AM
Originally posted by bldavis11
Bumpin,
-Ben
I used part # 9709T19
I also see some interesting stuff that would be better than carpet padding i think...54495T57 Not sure, but I think it would insulate better than carpet padding and provide all of the noise reduction characteristics.
Steve
Old Mar 12, 2003 | 11:15 AM
tomstin's Avatar
Check out this thread:
http://forums.delphiforums.com/tacom...es?msg=74967.1
Raammat and foam camping pads..
Old Mar 12, 2003 | 12:05 PM
Bob_98SR5's Avatar
Bumpin,
Two questions: does this stuff need to be applied with a heat gun? Also, does this stuff smell like tar or anything funky?
Thanks,
Bob
Old Mar 12, 2003 | 12:52 PM
x4RunnerTM7x's Avatar
dynomat was intended for speakers and noise dampening for the speakers...i personally have dynomat thoughout my truck and it really doesnt help outside noise..you can tell the system speakers sound louder and more sharp...i still think its not worth the money for the minute performance (10 to 15 percent)
Old Mar 12, 2003 | 01:01 PM
Originally posted by Bob_98SR5
Bumpin,
Thanks,
Bob
nope, with hi temp mastic, no need for a heat gun. It does however have a wierd smell that stays for about 3 or 4 days after that it's gone.
Old Mar 12, 2003 | 05:46 PM
ATC's Avatar
ATC
Bumpin' Thanks for the tip on the 8# pad. I took everything out today & installed it in my 4Runner from front to back. It has made a significant difference in the interior road noise. If anyone want to do this just go to Home Depot & buy the 6'x9' 83 pd they sell. It cost $20 bucks & was worth the 2 hrs it took to install.
Old Mar 12, 2003 | 07:06 PM
One thing I haven't done, but will be doing soon is to add the padding to my door skins. As I said already, all 4 of my doorskins have the hi-temp mastic, but Ive been thinking about using 3M tac 90 spray adhesive to anchor a layer of this padding. Then sealing the door with another layer of hi temp mastic inplace of the door seal. This would REALLY knock out road noise form the doors.
Doing the roof helps BIG TIME....2nd gens are easy to get to the roof skin but it just takes forever. Then there's the hood - you can replace the insulation with some sort of aluminum based asphalt adhesive on the hood.
My goal is to be able to drive at 80mph and not even realize the engine is running....
Once my test is over this next wed, Ill do a full write up on the mods Ive done on my truck....
zytra
Jan 24, 2019 03:16 PM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
