A/C burnt rubber smell
Old Apr 5, 2004 | 08:49 AM
Sbrut95's Avatar
On my way back from Vegas last week I started to smell a burnt rubber smell coming from my vents. I had the A/C on and it was NOT on recirculate. I though, "Naw, it cant be me, it must be from the outside." But after testing it out, I realized it was me. My A/C isnt spittin out cool air any more, just warm. Any ideas?? Thanks
Old Apr 5, 2004 | 09:29 AM
MTL_4runner's Avatar
I think you may need to have the system evacuated and tested for leaks.
Check all your belts to see if they are tight and if any seem glazed.
Also check to see if the AC compressor turns over and is not seized.
Old Apr 5, 2004 | 09:35 AM
Sbrut95's Avatar
Originally Posted by MTL_4runner
I think you may need to have the syatem evacuated and tested for leaks.
Do you just mean does the compressor come on when I engage the A/C. Cause I can hear it engage but it sure isnt working right.
by the way, thanks for that post on the electical for my year and model. Im excited to get that taken care of.
Old Apr 5, 2004 | 02:08 PM
If you can see or hear the clutch engage then you should just need to recharge the system.
Take it to a shop and have them pull the system down (ie hold a vacuum) and refill.
Old Apr 5, 2004 | 03:36 PM
jrok's Avatar
it could be partially working (engaging with a click) but just not turning as fast as it should be -- thus heating up the belt. the fact that the rubber smell and the lack of cold air occurred at the same time would seem to indicate a loose belt or a failing clutch.
Steven.m.paulk
Jun 7, 2020 10:45 AM
puddlepirate
Jul 30, 2016 06:29 PM
Badlander
Oct 10, 2015 08:05 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
bryan34w
12
Sep 30, 2015 02:50 PM
