A/C is broken
Old Apr 13, 2007 | 08:53 AM
Shirleyda4runner's Avatar
A/C is broken
Ive searched the forums the best I can but I cant decide which way to word the search... ac..a/c...air conditioner...air conditioning... either way the thing that is sposed to keep me cool is not working, and so I'm going to post my question.
I had a 3 hour drive yesterday and I think something may have gone wrong on the way home, I try and turn on the air conditioning today and nothing. The light lights up and the fuse isnt broken and the compressor is turning. I've deducted that I must have a leak. I havent charged the system since I had it replaced 2 years ago. My question is can the freon run almost instantly without a leak in the system or would it slowly be less and less cool?
Also, if there are any other things I could do a visual inspection of please help. Thanks again, hopefully this is an easier fix.
Old Apr 13, 2007 | 09:23 AM
NaeSLaS's Avatar
if it had a leak, then it can all leak out overnight (well, enough to cause it not to turn).
At the same time, if the pressure of the freon isn't to the right amount, then the AC relay shouldn't activate the compressor.
Old Apr 13, 2007 | 09:42 AM
mkgarrison5's Avatar
do you hear a "tic" when the compressor comes on?? or does the compresser even come on?
Old Apr 13, 2007 | 10:31 AM
no tic that i remember, The truck doesnt even go to a higher RPM when i turn it on. Is it the compressor then?
Old Apr 13, 2007 | 10:34 AM
MTL_4runner's Avatar
No, that means you probably have a leak and all the refrigerant is gone. The lines have a pressure switch that won't let the clutch come on if there isn't enough refrigerant in the system and you might damage the compressor. AC stuff is not a DIY job, take it to a shop and have them pull a vacuum on the system and see if it holds. If yes, refill with R-134. If not, start looking for the leak.
Old Apr 14, 2007 | 12:12 PM
Ironmike4x4's Avatar
I'm glad someone else knows this.... also you are supposed to have an AC license to even work on it. Also if a shop tells you they cannot "top off" refrigerant because it's against the law then tell them about the EPA Customer Rights to Refrigerants regulations. Then they will be stuttering. It states unless the local or state laws prohibit it then a customer can have refrigerant "topped off." Like MTL says, take it to a shop and have them to pull a vacuum to determine a leak. If there is one they should put dye and oil and recharge. Come back a few days later and they can use a UV light to find where the leak is coming from.
Old Aug 13, 2007 | 06:18 PM
infiltrator's Avatar
okay, i need help on my ac
it gets really hot out here in california, and i love my 4runner ac it works GREAT.
but, one night im driving home and its hot, and i try the air, nothing.
it blows air, but hot air, and the heater of course still works.
what can i do? i dont hear a click?
are compressors expensive?
Old Aug 13, 2007 | 06:52 PM
wow, no one can help me?
Old Aug 14, 2007 | 06:53 AM
RacerX's Avatar
I have heard about quite a few people using ES12 over R134a.... I fixed and recharged a friends 86 BMW with the stuff and it is pretty impressive, mainly b/c the compressor didn't seem to have so much drag on the system... especially when the crank fan is spinning with the 100 deg weather we have.
Old Aug 14, 2007 | 07:03 AM
Belize Off Road Team's Avatar
mine is in trouble too, i have had no A/C for about 7-9 months now, but here in Belize it is not easy to find someone qualified. if you find out the problem, let me know so i can try it on mine
Old Sep 19, 2012 | 11:32 AM
Hieb's Avatar
Check your belts. If there's no drag on the engine that may be your first clue. If all check out then start investigating the piping. Look for Signs of leaks. Ex oil residue. If nothing still take it in and have a system check then a pressure check.
ladybugRC
458
Aug 21, 2020 10:41 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
Badlander
Oct 10, 2015 08:05 PM
bradahman
Oct 1, 2015 09:24 AM
Brodetski
Sep 30, 2015 11:50 PM
