Busy weekend of mods!
Hey guys,
Well, as some of you know, I installed an OME steering stabilizer on my rig this weekend...but unfortunately had a little trouble. Anyway, all is good now.
However, Jonathan and I also installed a few other mods on my rig this weekend: extended rear diff breather, greasable rear swaybar bracket bushings, rear swaybar end-link bushings, front swaybar disconnects (made by Lee), and the OME stabilizer.
It was a pretty busy day, but a good one. If you are interested, please see my Webshots page (album 4Runner #2) for pics of the mods. Also, if you need part numbers for any of the above mods, just let me know and I'll get them for ya. Take care guys-
Cody
http://community.webshots.com/user/ctbtiger
Cody
I've been running Lee's discos for a while now and I'm got a little noise up front. The threaded part of the "heim" connector is undersized for the hole in the sway bar. I've cranked them down twice (w/thread locker), but you really need to gorilla them to keep them put (as far as I've found). I'm concerned that I'll snap the thing off if I go any tighter. I'm going to look for a steel bushing to put in the swaybar end, or I'll make my own set with beefier parts.
Let me know how they are treating you after a month or so.
Drivability is still great, just a little clunking.
I'll be sure to let you know how they work for me Mike. If I have any problems, you know I'll be headed right back here...
However, it shouldn't be bad at all to have to throw the stock ones back if need be. I'm anxious to try out the new disconnects on some trails up by school.
nicely done...... quick question though, how much of a PITA was it to get the rear swaybar end links unbolted to change the bushings?
i ended up making some front end links (thanx to Robinhood150's website) myself cause i snapped the stock ones trying to unbolt them and i didnt want to pay $100+ for the replacement ones form toyota.
just wondering how succesful you were with the rear ones?? any big issues with them??
Originally posted by Jonathan
Well I'll tell you. I helped Cody put those on and we didn't run into any problems whatsover with them. Very simple and quick install. If you replaced your front endlinks you will have no problems with the rear. Just make sure you hold onto the shaft that connects to the endlink, as it likes to rotate when you start wrenching on it.
Toys4parts
Sep 26, 2015 01:56 PM
