bumper relocation
Old Sep 4, 2003 | 12:32 PM
'91yota's Avatar
Question bumper relocation
hey i bought my truck about 3 or 4 months ago and i was wondering what i can do about my rear bumper. it has a 3" body lift on it so the bumper has a gap and is lower than stock. just wondering if anyone knows of a kit, or what i could do for a 91 toyota. its a v6 4x4.thanks.
Old Sep 4, 2003 | 06:40 PM
evilcow's Avatar
http://www.4wheelparts.com/product2....=GSPACC&cat=EA
Old Sep 4, 2003 | 07:44 PM
Yoter's Avatar
Guest
www.4crawler.com
Old Sep 10, 2003 | 03:14 PM
'91yota's Avatar
thanks that makes it alot easier. also is very hard to put in?
Old Sep 10, 2003 | 03:27 PM
Yoter's Avatar
Guest
there are four nuts to remove on the inside of the front of the bumper and one on each end. I found it easier to remove the grill and turn signals to access the front nuts. I think it was a 12 or 13 MM that I used on all of the nuts. First start at the sides pulling back the inner fender skirting and you will see a nut. There is an L shaped bracket that comes off with the bumper. Its easiest to remove it with the bumper so the install will be simple. Once the sides are off and the fronts are off get a firm grip on the bumper pulling from the bottom outward and up. then install your new brackets and install is the opposite of removal. I think I explained it right, lemme know if you have problems.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Scotttekoch
Sep 28, 2015 10:30 PM
83
Sep 27, 2015 04:13 PM
Toys4parts
Sep 26, 2015 01:56 PM
