Bubbles on oil Dipstick
Old Nov 13, 2002 | 02:46 AM
MonkeyElvis's Avatar
I saw this on my dipstick when i was checking fluids, and I was wondering if this is normal, or if I should be worrying about something. they don't have any particular color to them, they just look like little air bubbles. anyways, i would appreciate any info. Thanks
Old Nov 22, 2002 | 08:49 PM
DubCab73's Avatar
when you change your oil....do you see coolant mixed in with it?
seems pretty strange to have bubbles in your oil
Old Nov 22, 2002 | 11:59 PM
butnut's Avatar
Unscrew your oil filler cap. Look underneath...see water drops or non oil looking bubbles? If so, you have some coolant leaking into your oil. How's your coolant level? If there's coolant in your oil, you may risk damage by driving. If there's no coolant present, I don't know about those tiny bubbles. Good luck.
butnut
Old Nov 23, 2002 | 02:35 AM
Jay's Avatar
Jay
I have seen bubbles in the oil before. No cause for alarm. Get it good and hot and i think they will go away.
Jay
Old Nov 23, 2002 | 07:38 AM
HBoss's Avatar
If it's there everytime you check, it's probably not a good sign. When the oil is churning in the engine with air, it's going to foam a little bit, however it shouldn't stay. It's like boiling water with the lid on. Water, compressed in there with some air, heats up, starts moving, you see foam on top..unavoidable.
Motor oil, as a viscous fluid (and the fact that it contains additives), tries to get the foam to dissipate quickly as foaming retards heat conductivity and promotes engine wear. Things such as water (or coolant, as above) encourage foaming so that may be all it is. If you see bubbles on the dipstick consistently , I'd say change the oil first. Perhaps it just has some water, coolant, etc. in it.
Old Nov 23, 2002 | 09:48 AM
Krash's Avatar
mine was doing this over at a buddy's right after changing my oil, and this was whte weekend after I changed the timing chain and guides etc etc etc. I gotta agree with Jay after it got hot they went away. Now when I check it everytime I fill my tank it has no bubbles cause its nice and warm.
the1998sr5
15
Jul 14, 2020 08:35 PM
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
93toyoguy
Aug 2, 2015 07:41 PM
adammtb
Jul 27, 2015 11:57 AM
