broken stud on top of Donahoe coil over
Old Oct 8, 2005 | 06:42 PM
swerks's Avatar
Just noticed today one of the studs on my new Donahoes is sheared off.
How does this happen ??? the shock is only 4 months old. :pat:
Old Oct 8, 2005 | 07:18 PM
keisur's Avatar
My guess? Too much make-up torque during assembly (manufacturer) causing the stud to have either tensile or torsional failure. Basically like over torquing a bolt and snapping the head off of it, only in this case, it was torqued just enough to stay together but still cause a stress fracture that eventually completely failed. If you could post a pic more of a top view looking down at what's left of the stud it'd be easier to diagnose.
Old Oct 9, 2005 | 07:24 AM
swerks's Avatar
Angry
how long can I get by with just the two bolts????
Old Oct 9, 2005 | 09:44 AM
BruceTS's Avatar
Looks like it was overtightened during installation, it would be quite easy to remove the broken stud, but you'll have to remove thw coilover assemble to gain access.
As long as your not taking it offroad, the 2 remaining blots will hold it in place.
Old Oct 9, 2005 | 11:51 AM
swerks's Avatar
Will I be able to just replace that stud or will I have to get a new top for the coilover ???? Heres a better pic.
Old Oct 10, 2005 | 06:06 AM
keisur's Avatar
Oh. I thought you were talking about a center bolt, like at the end of the piston rod or something.
I wouldn't worry about it much but just fix it ASAP. Like Bruce says, don't wheel with it like that.
Old Oct 10, 2005 | 01:27 PM
swerks's Avatar
what would be the easiest fix. I have contacted Donahoe but have not recieved a response back. can I just repace that stud or do I need a whole new piece????
Old Oct 10, 2005 | 02:57 PM
JGM's Avatar
JGM
If the 2 in place are good, then you are okay for now, but how do you know they are okay? Just playing the devil's advocate.
Old Oct 10, 2005 | 09:46 PM
swerks's Avatar
I dont, what would be the easiest fix. I have contacted Donahoe but have not recieved a response back. can I just repace that stud or do I need a whole new piece????
Old Oct 10, 2005 | 11:35 PM
jimbo74's Avatar
jsut replace the stud... all you need to do is pull the shock out, go to the hardware store and match the stud.....
Old Oct 11, 2005 | 01:16 AM
swerks's Avatar
It sounds simple and hopefully it is, but this is a male stud inserted in to a top plate Im not sure how you get it out. it does not go through the plate.
Old Oct 15, 2005 | 01:24 PM
BruceTS's Avatar
Two ways to remove that broken stud, first use vice grips to unscrew the stud out of the top plate. If you have a welder lay a nut on top of the stud and weld it, then simply unscrew it out.
the1998sr5
15
Jul 14, 2020 08:35 PM
mr_manny
Jul 31, 2015 10:39 AM
Numberonedad6
Jul 30, 2015 07:10 PM
ddg71
Jul 24, 2015 01:24 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
