Brakes Seizing up.
Old Aug 17, 2006 | 07:20 AM
a10acboy's Avatar
Brakes Seizing up.
O.K., maybe this is an old subject, but my brother called with a problem. His front brakes are locking up on his 97 4x4. Based on advice he replaced both brake calibers, but this did not solve the problem. My first thought would be the master cylinder. I don't know exactly how they work, but I would assume that there would have to be some type of relief valve or something that allows the fluid to flow back slowly. If this were clogged of malfunctioning, then this could be causing the problem. Any ideas? Please help.
Old Aug 17, 2006 | 07:26 AM
kevin444's Avatar
if it aint the drums, in the back, could the brake cylinder in the drum area,
could be the LSPV?
could be the master cylinder?
Old Aug 17, 2006 | 07:51 AM
a10acboy's Avatar
What is a LSPV?
Old Aug 17, 2006 | 07:53 AM
wjwerdna's Avatar
load sensing proportioning valve? i believe its over the rear axle, has a lever thingy on it
Old Aug 17, 2006 | 07:59 AM
a10acboy's Avatar
Would that affect the front brakes? The rear brakes are not locking up.
Old Aug 17, 2006 | 09:17 AM
eric-the-red's Avatar
First let's clarify the problem a bit, in the title you say seizing up and in the post you say locking up. To me those 2 terms mean different things. Are the brakes locking up when braking, ie skidding tires, smoke etc; or are they seizing up and staying on after use. If it's the second I would replace the rubber lines in the front, sometimes they get swollen inside and prevent the brakes releasing. If that doesn't solve it then it could be the return port in the master.
If they're locking up and skidding when braking it could be the LSPV needs adjusted to send more force to the rears, or maybe he just needs to push a bit less
Old Aug 17, 2006 | 09:57 AM
a10acboy's Avatar
The front brakes are seizing (or not retracting), staying on after use. I'll have him check the rubber break lines and take a look at the master cylinder. Sorry for the confusion and thanks for the help.
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
okamikai
Apr 30, 2018 10:19 PM
Sr5crawler
Jul 31, 2015 12:32 PM
CanRunner
Jul 20, 2015 01:29 PM
