Brakes?
Old Mar 23, 2003 | 06:57 PM
ChitRod's Avatar
Brakes?
Ok I have a 96 SR5 with the 16 inch wheel package and I can't get brakes to last more than 9 months. Is there a longer better lasting Brake pad? or do I just need to change my driving style, or is that just how brakes are going to be on the 4runner?
Old Mar 23, 2003 | 08:36 PM
Sludge's Avatar
First off what type of pads are you useing. Second changing your breaking pattern by down shifting will help your pads and rotors out to some degree.
I currently use the Raybestos IQ(Import Quality) Pads and they seem to hold up well for me.
Old Mar 23, 2003 | 09:57 PM
Red Chili's's Avatar
Did you notice the brake dust build up on the wheel after replacing the brake pads? If so, it probably has the carbon graphic stone instead of semi-metallic pads. I remember a several years ago, Toyota offered two different types of brake pads for my older 1989 4Runners, carbon pads wear out more rapid than semi-metallic. I don't know what brand name or what type of pads did you replace?
My current '98 4Runners still has original brake pads at 143k miles since I bought new. I think it is a semi-metallic. My driving habit on highway is more like a race driver through the Colorado Rockies.
You may want to check on the semi-metallic pads replacement kit at your local dealer or auto part store. Also, you need to check the rear brake adjustment.
Old Mar 24, 2003 | 07:28 AM
ChitRod's Avatar
I don't know what type of brake pads. I do know that i drive like Dale Jr. and don't hit the brake till i want to stop, but bad habits are hard to change, although i've started driving slower now.
Old Mar 24, 2003 | 07:29 AM
ChitRod's Avatar
yep lots of brake dust, and I drive pretty much like you do, does semi metallic pads require any special rotors or anything?
Old Mar 24, 2003 | 02:59 PM
Nope, you can use the original (or OEM) rotors to accept semi metallic pads as long as rotor is in a good condition, not wrapped or worn out.
Old Mar 24, 2003 | 06:02 PM
White SR5's Avatar
Post La la la la!
Cardon graphite pads provide better performance, but as you know, graphite is soft, so they wear out quickly (and produce a lot of brake dust). I'm guessing you have that type. My dad does and his wheels won't stay clean for 3 days. My wheels, on the other hand, will stay clean for weeks. I've had the OEM brakes since I got the car, but I think I'll try the carbon kind to see the difference. I need new brake pads anyways. I'll report back after the swap.
Zach
Old Mar 24, 2003 | 06:07 PM
ChitRod's Avatar
Yeah my wheels won't stay clean for a day after i wash them.
Old Mar 24, 2003 | 06:20 PM
slick858's Avatar
Raybestos QUICK STOP SERIES is a exclusive blend of ceramic ingredients that provides the quietest and cleanest braking capabilities, while delivering increased stopping power and the highest level of safety. QUIET STOP Disc Brake Pads are designed for today's drivers who want ultra-quiet braking, ultra-low dusting on their wheels, and exceptional durability.
get rotars trued up, just email me ill tell you everything
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
