"brake" light...
Old Mar 30, 2003 | 08:08 PM
turboale's Avatar
"brake" light...
Just yesterday I noticed that the brake light (same as the handbrake) light comes on while under accelearation. Not heavy, just mild steady acceleration. Does that mean I need a new parking brake, or does the car use the same brake light to tell me I need brake fluid (that would make more sence) I checked the lever, and it is firmly all the way down.
Thanks!
Old Mar 30, 2003 | 08:10 PM
44Runner's Avatar
Re: "brake" light...
yes
Victor's Avatar
yup - brake fluid. There is a float in there that moves as you accelerate. I'd check the front brake pads thickness - the calipers are very open and taking in all your fluid.
Old Mar 30, 2003 | 08:24 PM
RTdawgs's Avatar
could be pads too.
Old Mar 31, 2003 | 07:18 AM
turboale's Avatar
Thanks guys, I'll go check both out...
Old Mar 31, 2003 | 08:53 AM
BTOWN4RUNNER's Avatar
Thanks!
I had the EXACT same problem about a month ago and it turned out to be low brake fluid. Put some more in and you'll be good to go. :fireman:
Old Mar 31, 2003 | 10:11 AM
rowan's Avatar
hey austin. i had that a little while ago too. my fluid level was just under the max line, i put a little bit in, right at the max line... and no more light.
Old Mar 31, 2003 | 05:05 PM
Toyota Punk's Avatar
Me too. Happened in my '94 and turned out to be low fluid.
ChefYota4x4
Jan 14, 2016 05:02 AM
4x4YOTA
Aug 15, 2013 03:59 PM
bddold
Aug 27, 2012 06:54 PM
YotaFun
150
Oct 11, 2011 04:44 AM
