Boost gauge & gas smell
Old Aug 26, 2003 | 02:14 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Question Boost gauge & gas smell
I just installed my SC & boost gauge on Saturday. Now, whenever I hit the throttle, I can smell a faint odor of gas coming from the boost gauge. I hooked it up in line with the FPR & the boost port according to the instructions, but I don't think I should be smelling gas. The connections seem tight so any suggestions are welcome.
Also, has anyone replaced the stock plastic tubing that came with the gauge with something more durable? The tubing and compression fittings like to kink and don't seem to be of the best quality.
Old Aug 26, 2003 | 02:39 PM
SLC Punk's Avatar
PM Manymods, he had the same problem.
I think it had to do with the boost gauge line not tightened down at the back of the gauge...
Old Aug 26, 2003 | 03:28 PM
Mad Chemist's Avatar
I don't have a clue what the tubing connections look like on the boost gauge, but some Teflon tape on the fitting threads would give a good seal if its leaking from there.
Old Aug 26, 2003 | 04:03 PM
Gadget's Avatar
Tighten the compression fitting on the rear of the gauge. You are not the first that this has happened to.
Gadget
www.GadgetOnline.com
Old Aug 26, 2003 | 08:28 PM
Thanks, will work on that tomorrow.
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Aug 19, 2015 02:15 PM
mikeyd6789
Aug 4, 2015 11:51 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
