Body lift and 315's are on! !!Now with pics!!
Old Oct 28, 2006 | 12:22 PM
  #41
04 Rocko Taco's Avatar
Looks great! very clean, very proportional!!
Old Oct 28, 2006 | 01:28 PM
  #42
d0ubledown's Avatar
Originally Posted by 4runnin2
Couple pics of the gap between the tire ans A-Arm. These Are Total chaos arms and 315/75/16 tires mounted on 16x8 wheels with 4.5" backspacing. There is about a 3/4" gap.
yowzas..thats tight. looks like its gonna have to be spacers for me. maybe 1"...dont really want to go that route..but uca's are just too damn tax for me at the moment...
thanks for showing me how much money and effort it takes to properly fit 35's..
Old Oct 28, 2006 | 02:05 PM
  #43
EstheticAngel's Avatar
oooohh...very very nice. i loves it. i can't wait to get my 315's on! woohoo!
Old Oct 28, 2006 | 03:31 PM
  #44
FredTJ's Avatar
Originally Posted by d0ubledown
<SNIP>
But he's not done yet.
Still needs to regear
Fred
Old Oct 28, 2006 | 03:34 PM
  #45
FredTJ's Avatar
Originally Posted by AH64ID
Not at all.. thats about what I paid for 5 35BFG muds with 100 miles on em, but that was a few years ago before rubber skyrocketed...
Yeah, not a bad price.
I paid about $175.00 each for the 35 MT/R's (Q) last time I bought 'em, about a year and a half ago.
Fred
Old Oct 28, 2006 | 03:36 PM
  #46
FredTJ's Avatar
Finally did my sig. Still running stock 4.10's right now. I plan on ordering 4.88's for it soon though. It is an Automatic so I do feel the power loss. I find myself driving in Drive more than overdrive to compensate for some of the low end take off. On the highway it isn't to bad at all, Just sucks in the 3-4000 rpm range.
You may wish to consider 5.29's over the 4.88s.
I'm running 4.88's with 31's now and would think that 33's are about it for that ratio.
Fred
Old Oct 28, 2006 | 04:39 PM
  #47
4runnin2's Avatar
ALTNR8,
4crawler offers a 2" bumper lift bracket for the front bumper That is why there is no gap.
Fred,
Do you have a 4cy. or 3.4? The stock setup of 4.30's and 31's was plenty peppy for me and 20 mpg wasn't to bad either. Right now I am getting about 16-17 mpg. 5.29's would be good if I off-Roaded it alot but in reality I drive more highway than off-road and with the 4.88's I should get back into the stock range and better gas milage. Plus can you fit an ARB with 5.29's in the front 7.5?
Old Oct 28, 2006 | 04:52 PM
  #48
d0ubledown's Avatar
16mpg on 35's automatic on 4:10's? is that even doable? does the thing take forever to accelerate or what? im on 33's w/ 4:30's auto and its sloow. no way i can get 16mpg...
Old Oct 28, 2006 | 05:00 PM
  #49
4runnin2's Avatar
Just checked my Gear set up options here since I'll be getting it done this coming week.
These are rated at 60mph
4.88 gear running 60 mph with OD should be 1996 RPM
4.88 gear running 60 mph without OD should be 2928 RPM
5.29 gear running 60 mph with OD should be 2164 RPM
5.29 gear running 60 mph without OD should be 3174 RPM
Now stock was:
4.32 gear Running 60 mph with OD Should be 1967 RPM
4.32 gear Running 60 mph without OD Should be 2885 RPM
Courtesy of Randy's Ring and Pinion Calculators.
Fred, You should be running: (with 4.88 gears and 31's at 69 mph)
with OD 2222 RPM
without OD 3259 RPM.
Does that sound about right?
Old Oct 28, 2006 | 05:01 PM
  #50
4runnin2's Avatar
Sorry doubledown, I have 4.30 gears I believe. It is an automatic
Old Oct 28, 2006 | 06:49 PM
  #51
FredTJ's Avatar
Now stock was:
with OD 2222 RPM
Well, I'm actually over here from the Gen II group ('95 4Runner, 3.0, auto, 31's).
I'm turning 2500 rpm's doing 60 mph (with OD and TC locked up).
Remember that with larger tires, you can't just get back to stock rpm's at any given mph and expect the power to be the same. It won't.
You'll need to actually run at higher rpm's.
Besides the larger tires and wheels weighing more, you also have the added burden of the increased leverage required to turn the larger and wider tires.
Fred
Old Oct 28, 2006 | 06:51 PM
  #52
FredTJ's Avatar
ALTNR8,
Fred,
I actually have the 3.0.
I'm running a '95 (gen II) 4Runner.
I'm getting right at 18 mpg as the rig is currently set up and that's most in town driving.
Fred
Old Oct 28, 2006 | 07:12 PM
  #53
AH64ID's Avatar
Fred
I have 4.88's and 35's. Its a great combo, my speedo is w/in 1%. Fred is correct that you should run a lower than stock ratio. But I will say that on the road this setup is great. 3rd gear at 4500 is great speed up hill, all relative (64mph). But I think overall 5.29's would be better offroad, but onroad I really like the 4.88's... I have enough power to pull hills at 4500 in 3rd, and 5.29's would cost me 5 mph, thats a buch when climbing long hills. I also have the heavy flywheel so my 1st gear torque is much better. You have a 3.4, so 4.88's also may be enough... WATRD only has 4.56's... grated he has a S/C as well, but also a ton more resistance.
Now stock was:
with OD 2222 RPM
It looks like you used the rolling diameter.. good deal, dont see a lot of people use it.
What did you use for OD gear? I got the same numbers for D, but my OD numbers are different. OD should be .705.
On a 2nd gen you can, havent heard anthing saying different on 3rd gens.
Old Oct 28, 2006 | 08:28 PM
  #54
4runnin2's Avatar
AH64ID,
I was taking the second figure from the calculator AOD (Automatic Over Drive). Isn't that right? That was the way I understood it.
Old Oct 29, 2006 | 04:17 AM
  #55
AH64ID's Avatar
Which calculator did you use?
The numbers you have are very close, w/in 50 IIRC
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Michael oaks
Jul 27, 2015 11:47 AM
Backcountry411
Jul 24, 2015 08:06 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
