Blown CV Joint Boots (Again!)
Old Jan 3, 2012 | 01:06 PM
MaltDisney's Avatar
High angle CV boots for 2nd gen runner
Originally Posted by FogRunner
What you want is a high angle CV boot, they are specificly designed for tolerating high lifts on IFS axles.
Only drawback is YOU have to pull the CV joint off the axle and install the boot and then put the axle back together because no one seems to sell them assembled.
Off road solutions of one of several companies that carries high angle CV boots .. http://www.offroadsolutions.com/96-02_4runner.html
I've known several guys that run these with lifts over 3" and never had a problem.
FOG
I have read that some people use the boot from a porche 930, the boots are made by offroad-engineering, and are tapered and flexible. The application that they use them for is the 95.5-02 years and I'm wondering if anyone has used them on a 2nd gen? any other high angle CV boot sugestions for a 94 runner would be great. I have a 94 sr5 with a 2" suspension lift
Old Sep 7, 2012 | 07:50 AM
ReptarSmash's Avatar
Originally Posted by JWaldz
dang! That's a good little angle, even with a dif drop. I think that's about what mine looked like before the diff drop and I threw both boots and one axle actually broke offroad before I got mine in. That was just me being stupid though. I've replaced both axles since then and have yet to see any signs of wear and tear. Been roughly 4 months. I don't think you should have to be going through boots/axles every year unless you're doing offroad more than on road. But with that angle I can see why you are.
For reference, here is mine before the dif drop..
Do you have a picture of the angle after the diff drop? Just ordered the OME 3 inch lift and after being assured the brake lines and steering shaft wouldn't need adjustment, I'm now worried I'll need to do CV joint upgrades
Old Sep 9, 2012 | 02:11 PM
cpizzle42's Avatar
Only one real CV joint upgrade.
http://www.rcvperformance.com/produc...ku=CVJIFS-TOY1
You just need a diff drop.
Old Sep 10, 2012 | 01:01 AM
drkblu4runner's Avatar
You NEED manual hubs if you don't like replacing cv axles every year or so
Old Sep 14, 2012 | 04:04 PM
  #25
hrt4me's Avatar
good info, thanks!
4x4YOTA
Aug 23, 2016 09:08 AM
alexcarey
Oct 14, 2015 06:05 PM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
Toys4parts
Sep 26, 2015 01:56 PM
