Blinker sound and clock dimming over and over
Old Sep 22, 2012 | 10:00 AM
RockyMtnToy's Avatar
96 tacoma 3.4L
My truck started making a beeping sound like the blinker does, but the blinker isn't on and the clock dims like i'm turning my lights on and off. It will beep sometimes for a minute, other times for a second.
EDIT: The corner lights light up in tune with the beeping, along with the brake lights and the light that shines on the license plate.
If this isn't the right section lemme know, and i'll post it in the correct section. Thanks!
The blinking and beeping continue even with the key removed.
Old Sep 23, 2012 | 12:49 PM
A friend mentioned it might be a ground wire, any thoughts?
Old Sep 23, 2012 | 01:08 PM
habanero's Avatar
Something to do with the headlight switch or a bad relay or the hazards and clock wiring doing something it's not supposed to (next to each other on my 4Runner, dunno if yours is the same)? The only thing I know about electrical stuff is that I don't know about electrical stuff.
Consider this a bump.
Old Sep 23, 2012 | 02:26 PM
Hadn't thought of a bad relay, thanks!
Old Sep 24, 2012 | 09:33 PM
So I pulled an in-line fuse under the dash and the ticking and blinking stopped but I lost the instrument cluster light. Everything still worked, just no back light.
Old Sep 25, 2012 | 12:04 PM
habanero's Avatar
So the clock and markers are working correctly but the back light's not?
Old Sep 25, 2012 | 09:57 PM
Correct. I haven't done anything at all and now the backlight is working again.This whole thing has me and all my friends confused.
I forgot to mention the flashing and beeping will happen even with the key removed.
Old Sep 25, 2012 | 10:27 PM
wyoming9's Avatar
Red face
Does this have a Alarm???
If it does I would check that out.
Sounds like an alarm issue to me.
These things can be a royal pain if you don`t have the remotes or any info about it.
Old Sep 26, 2012 | 12:56 PM
I have a Viper alarm. I have a little tab that I swipe so I can start it. I have no info on it tho.
What would you suggest my next move would be?
EDIT: I feel stupid now, the back light was just the little knob turned all the way down...
RyanJ989
11
Apr 7, 2021 09:41 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
langry345
Sep 14, 2015 03:36 PM
ac7822
Sep 11, 2015 08:49 AM
seab1209
Sep 3, 2015 05:41 PM
