BL and 285's are on (pics)
Old Jul 7, 2005 | 06:56 AM
ARB4STUNNA's Avatar
Finally got the body lift and 285's on yesterday. I had the same problem that someone else on the board had with the tires rubbing on the A-arm at full droop. The guys at discount didn't want to put them on, but once I told them to drop it down they saw that the barley cleared. I jacked up the front end at home to test it again and at full droop the just barley rub, the tire still spins though. Is this a problem I should worry about before I take it off-road again?? It didn't seem like it was rubbing enough to blow it out or anything. Anyone else's 285's rub like that?? Thanks
Old Jul 7, 2005 | 07:57 AM
Jboy's Avatar
Nice
Old Jul 7, 2005 | 08:10 AM
User 051420's Avatar
This happens to a lot of people. To fix it you'll need to either get wheel spacers, or a different wheel. Most have found that a 16x8 with 4.25-4.5" backspacing works the best to keep the tire away from the arm.
Good luck! Looks awesome!
4.34runner88
Feb 7, 2016 02:24 AM
Obmi
Nov 24, 2015 11:37 AM
bobjohnson2121
Sep 17, 2015 08:07 AM
HiLuxer
Sep 9, 2015 02:43 PM
