bilstein coilovers
Old Feb 7, 2004 | 08:58 AM
swerks's Avatar
Question new adjustable bilstein coilovers
any one know if these will work with 3rd gen 4runners. they are offered from allpro for tacomas, this is not the tundra version that has been available
Old Feb 7, 2004 | 09:44 AM
Spectre's Avatar
Are they adjustable?
Old Feb 7, 2004 | 10:18 AM
swerks's Avatar
yes, they are adjustable 0-3 in I believe
Old Feb 7, 2004 | 03:42 PM
Spectre's Avatar
eibach makes the coil and Bilstein are the shocks?
Old Feb 7, 2004 | 04:58 PM
Hyperlite's Avatar
3rd Gen 4Runners and Tacos are the same front suspension
Old Feb 7, 2004 | 07:12 PM
Dr. Zhivago's Avatar
Away
If they will fit on a Taco, they will fit a 3rd Gen 4Runner. However, just because they will fit does not mean they will work well.
Eibach makes springs, to answer someone else's question. The SAW's also use Eibach springs.
My .02
Dr. Z
Old Feb 7, 2004 | 10:18 PM
swerks's Avatar
yes, the springs are eibach. think the tacoma valving will be ok for a 4runner??
Old Feb 8, 2004 | 01:44 PM
swerks's Avatar
Is there a E-mail address for allpro I could not find it on their site. would like to get more info
Old Feb 8, 2004 | 05:18 PM
MTL_4runner's Avatar
The Tundra valving should be fine.
I would be a bit suspect of the quality before someone else had tried them.
They may be awesome......who knows?
Old Feb 9, 2004 | 01:25 AM
swerks's Avatar
I dont think the tundra version fits the 4runner
Old Feb 9, 2004 | 02:17 AM
calg3's Avatar
swerks: The only thing different about the Tundra is the top plate. The hole pattern is slightly different. when you go to the All Pro website you can find these in the Tacoma section. Also an e-mail address got for them is eric@allprooffroad.com for the sales/order fulfillment guy. Good luck.
Old Feb 9, 2004 | 12:30 PM
Hyperlite's Avatar
Slightly different, are you sure
Old Feb 9, 2004 | 04:04 PM
calg3's Avatar
I have never physically taken the two apart and compared them, I was going by what they stated in the Downey catalog. From page 114 of my 2001 Downey catalog, "The bolt pattern in the Tundra upper spring seat is slightly larger than the Tacoma bolt pattern." Then they go on to explain the difference in spring rates...
Since the Tacoma and 4Runner are interchangeable as far as the upper bolt pattern, I just thought I would point that difference out. It looks to me that the guys at All-Pro took the Tundra Coilovers from Bilstein and fabricated a new top plate that fits the Tacoma and maybe are using a different spring. The Tundra Bilstein coilover kit comes with progressive Hyperco springs according to the ads I have seen.
Old Feb 9, 2004 | 04:49 PM
swerks's Avatar
what would be ideal for a 4Runner the tacoma setup or the tundra??? seems more people were leaning toward the tundra valving with the saws.
Old Feb 9, 2004 | 05:01 PM
You said these fit a Tacoma but had Tundra valving.
If they fit a Tacoma they will fit a 4Runner too.
Old Feb 9, 2004 | 06:17 PM
Hyperlite's Avatar
does anyone know about the A-arms?
are they larger than stock?
better than ATS?
ZGjethro
Jun 7, 2017 11:04 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
toyotasaurus
Sep 24, 2015 03:30 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
