Big Ass 3rd Gen!
Old May 16, 2005 | 02:47 PM
  #41
NorCalVP's Avatar
Originally Posted by SEAN_at_TLT
Wanna see exactly how much "lift" is NEEDED to clear 35's even at full compression on a 4Runner or Tacoma????
With a little bit of trimming you can completely clear 35's with ZERO lift.
You said if you had the money or the time... Well the money is about $10 and the time is a day in the driveway and you can clear 35's.
We are running about ~4" of "lift" just because that happens to be the right amount so that the truck feels balanced between extension and compression travel. A lower center of gravity is better for wheeling period, big lifts are for looks and that's cool but don't make excuses about clearing tires or not skidding on skid-plates or whatever. Just admit that you like the look of a big old truck and that's it. You can't defend the undefendable. I'm not trying to bag on you but you have your facts bass-ackwards.
So do they still clear under full compression at full lock both ways?
Old May 17, 2005 | 02:15 AM
  #42
Bigkahuna808's Avatar
I dont trust that. If that was a SAS I can see the fender just tearing off and going flying down the trail. With IFS it woudnt be as bad. Less articulation, but still somthing I would never attempt
Old May 17, 2005 | 04:34 PM
  #43
RIS's Avatar
RIS
I've got a 91 with 15X39.5X15s on it with SAS & 529 gears. Its killing the auto trans and the 3.0 is slow but I can still get down I-10 @ 70mph. See if this works. photobucket.com/albums/y86/hienuf
Old May 20, 2005 | 12:53 AM
  #44
DudeBud's Avatar
Originally Posted by RIS
I've got a 91 with 15X39.5X15s on it with SAS & 529 gears. Its killing the auto trans and the 3.0 is slow but I can still get down I-10 @ 70mph. See if this works.photobucket.com/albums/y86/hienuf
no worky
Old Jun 18, 2005 | 11:06 PM
  #45
Stive2699's Avatar
How much do you think it would be to lift a 3rd gen like these...like the Semi good looking ones.. umm not the wild crazy graffiti "thing". and the pic on this page.. do u think it would look better with not so wide of a tire?? plz people dont go mexi on me.
Old Jun 19, 2005 | 05:55 AM
  #46
justinh's Avatar
just so you know that truck has as much or more flex than most straight axle trucks out there. try 14" of verticle wheel travel.
Old Jun 19, 2005 | 12:31 PM
  #47
Price from when I talked to my installer would be about $1800 for the front kit (fabtech) and about $600 for the rear install (downey/ OME spring, spacer, and pan hard). Labor on the kit would be about $700.
Its true that in some cases IFS has more flex, if you disconnect the sway bars. Other wise the flew is very limited. As for the fener trim truck, I would worry that if the wheels were locked in a turn, and the suspension traveled up, the tire would contact the body.
Old Jun 19, 2005 | 01:02 PM
  #48
justinh's Avatar
that truck has much more than fender trimming, you should check out his web-site or tota chaos or camburg engineering.
crammit442
7
Nov 29, 2017 12:30 PM
39 Thieves
Jan 6, 2017 01:08 PM
digitalracer
May 16, 2016 03:57 AM
izzmee
Aug 17, 2015 10:20 AM
CJ94yota
Jul 3, 2015 10:14 PM
