bad gas???
Old Nov 27, 2004 | 08:18 PM
epic37311's Avatar
bad gas???
Engine cuts out at high rpm and dies. Just replaced plugs and plug wires about 3 weeks ago and it just started running bad. Could it be bad gas or would it cut out all the time? Any opinions. By the way it is a carborated 22r with airhog filter and 4.10 gears so its around 60 mph when it does it
Old Nov 27, 2004 | 09:09 PM
kevin444's Avatar
you cleaned the carb?
Old Nov 27, 2004 | 09:27 PM
epic37311's Avatar
yeah with carb cleaner
Old Nov 27, 2004 | 09:49 PM
CAM 1's Avatar
Question
It's gota be the Air hog (fram) j/k. I got nothin......
Craig.
Old Nov 27, 2004 | 10:39 PM
jimbo74's Avatar
hows the fuel filter? my truck acts funny when mine is dirty
Old Nov 28, 2004 | 07:30 AM
-ToYoTa-'s Avatar
Maybe while changing the plugs, you knocked a vacum hose lose. and it has fell off? or has a split in it.???????
Old Nov 28, 2004 | 09:06 AM
User 051420's Avatar
Vacuum hoses, fuel filter...Which brand of plugs did you use?
Old Dec 2, 2004 | 02:48 AM
epic37311's Avatar
splitfire but its been over 2 weeks since i changed them. I think its the gas cause it does it sometimes now but not near as often.
Old Dec 2, 2004 | 04:57 AM
Arrow
Splitfire =
I am not a fan of splitfires. Put some denso or ngk's in that motor and that will help. What type of wires did you use? What about the cap and rotor? I would also definitley check the fuel filter. That is about all I can think of right now.
Oh yeah - Is the timing in check? Might want to check that too.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
daddio
Jul 18, 2015 10:20 AM
