backspacing question???
Old Aug 26, 2005 | 10:57 AM
YeloSub7's Avatar
So right now I am putting on pro comp's 4in susp lift, how much backspacing do I need on 15x8 rims with 33x12.5 tires? whats the min max i need to have? what options do I have to go with? My friend runs 3.5 backspacing on his, but i was just wondering what the min is?
Old Aug 26, 2005 | 11:30 AM
4Crawler's Avatar
Check with the lift kit vendor, some of tham have maximum backspacing limits. I think most are 3.75" or maybe 3.5". Minimum is whatever you want. Less backspacing = wider track = wheels stock out farther from the truck. More chances of tires rubbing, likely to need fender flares for legal tire covereage, etc. Generally 2" is about the least backspacing you can get on a normal wheel.
Old Aug 26, 2005 | 11:34 AM
YeloSub7's Avatar
well thats what i was wondering i guess is the max limit...
Old Aug 26, 2005 | 11:38 AM
4Crawler's Avatar
Again, either read the lift kit instructions or contact the lift kit supplier's tech support folks. They should know the answer, after all they were the ones that designed the kit.
Old Aug 27, 2005 | 03:10 PM
YeloSub7's Avatar
well i guess I'llk have to call cause I got the kit used from a friend doing an SAS...
Old Aug 27, 2005 | 03:41 PM
YeloSub7's Avatar
ok, i need to understand exactly how this backspacing works, I am really confused... so a wheel with 2 inches of backspacing would stick out more than whels with 4 inches of backspacing right?
Old Aug 27, 2005 | 03:42 PM
YeloSub7's Avatar
so if i got rims with 4 inches of backspacing I would be ok? with 15x8 and 33x12.5? on a 4 inch lift?
Luvmeye22re
Aug 4, 2015 03:53 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
