Axle shaft lenght??
Old Apr 2, 2003 | 10:42 AM
geauxturbo's Avatar
Axle shaft lenght??
I am going to put a '96 or up Tacoma 8 in the back of the heep and was wondering if the axle shafts were the same length on each side.
TIA
Greddy
Old Apr 2, 2003 | 11:15 AM
jx94148's Avatar
Hi and welcome!!
They are the same legnth on both sides.
I love the fact that we have Toys with Jeep axles and maybe soon, a Jeep with a Toy axle.
Old Apr 2, 2003 | 11:31 AM
geauxturbo's Avatar
Thanks for the welcome. Actualy, there will be two of us from Louisiana 4x4 doing the swap. We are going to split the cost of a pair of axle spares, which is why I needed to know if the length was the same.
I watched Yotas on 37s running all over Gilmer, TX without fear of failure. So, I talked to one of them and he looked baffled that I was having axle problems with 33s
After looking at the clearance of the taco 8 and the fact that it is darn near the exact same width, I decided to do something a little different. After I get the axle in I have to start searching for a TRD sticker for the tub
Old Apr 2, 2003 | 03:34 PM
FattyCBR's Avatar
Make sure your spares go with your axles. Pre 86 (85 and before) rear axles are shorter and have smaller brakes. Post 86 (start of IFS) have a wider rear axle with a thicker tube and bigger brakes. They are all 30 (?) spline so the pumpkins will interchange.
Old Apr 2, 2003 | 04:17 PM
toyota parts dude's Avatar
toy axles in jeeps
there are a couple guys in PA that swapped both front and rear toyota axkes into jeeps one is a around a 1990 wrangler and the other one is a jeep scrambler with a 304 v8 and he didnot brake any axles he broke the factery jeep ones though.
Old Apr 2, 2003 | 06:09 PM
sschaefer3's Avatar
Ed at Kongs/Maniac Metal Works was talking about swaping Toyota axles into his TJ as well.
Maniac Metal Works is building a Willys with a 22RE & Toyota axles.
Old Apr 2, 2003 | 06:48 PM
geauxturbo's Avatar
Re: toy axles in jeeps
Since you are Toyota Parts Dude, you wouldn't happen to have the skinny on the best place to find Tacoma axles would you?
Junk yards around Baton Rouge aren't too great.
Old Apr 2, 2003 | 06:55 PM
FattyCBR's Avatar
So are you going to use a Tacoma 8" (elocker) or 8.25" axle? I'm not sure what axle shafts are interchangeable with the 8.25" axle.
This place is good for Toyota parts:
White's Auto Sales 423-884-6075
Old Apr 3, 2003 | 05:21 AM
geauxturbo's Avatar
Let me make sure I have this right. The 95.5 and up Tacoma 4x4 and PreRunner that have the elocker are the 8" or 4 pinion design which is the same as the V6/Turbo diff. Without the elocker in the 95.5 and up Tacomas is the 8.25" diff or the 2 pinion design. All 95.5 and up Tacoma axles are 60" to 60.75" WMS to WMS depending on who measured it. My TJ axle is 60" WMS to WMS.
Both diffs have 30 spline axles....correct? I am planning on staying with 95.5 and up Tacoma axle. My wish list is an elocker and 4.56 gears. However, I will take a 4.10 elocked axle over an open 4.56 geared open axle.
I am going to have the shafts redrilled to 5 on 4.5 bolt pattern. Take the brackets off my exploded dana 35 and weld them on the taco axle indexed to the proper angle for my fixed yoke/ cv shaft. That way my springs in the rear won't be bowed out like they are now.
Old Apr 3, 2003 | 05:54 AM
sschaefer3's Avatar
86-95 Mini Pickups have an 8" rear
95.9-2003 Tacoma without e-locker have the 8.25" rear
95.9-2003 Tacoma with e-locker have the 8" rear
More aftermarket is available for the 8", Even the 2WD PreRunner Tacoma's with the e-locker have the 8" as well.
Old Apr 3, 2003 | 05:55 AM
sschaefer3's Avatar
Yeah you have it right.
Old Apr 3, 2003 | 07:05 PM
redrill problem
geauxtorbo your going to have a problem when you go to drill out the axles because the center hole on the drum is 3.9 inches and the axle sticks out past the drum. so the lugnut hols will be rite next to the inner edge of the drum. your wheels wont sit flat on the drum because of the axle. when you get wheels for a toyota the center hole is 4 inches so it clears the axle. just barelly fits. don't now of any yards close to me that even have any tacomas sorry.
88sasturbotoy
Jan 30, 2026 01:57 PM
A2theK
Jan 10, 2016 10:18 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
CratesCruiser
Aug 23, 2015 06:12 AM
ripp96
Jul 25, 2015 02:32 PM
