Automatic Transmission Sealant Question
Old Nov 29, 2006 | 02:09 PM
4Runnerman's Avatar
Hello all,
I just had my 4Runner transmission fluid swapped for Amsoil at what I thought was a reputable transmission shop because the dealer wouldn't do the swap with Amsoil. I won't bore you with all of the details, but I had to bring the truck there 4 times before they were able to keep the fluid from leaking out. However, I discovered today that they put the transmission pan gasket sealer in the filler tube joint along with the o-ring in order to guarantee the filler tube joint would not leak. I'm wondering if this could cause any problems down the road.
Please advise.
Thanks.
John
Old Nov 29, 2006 | 02:52 PM
MTL_4runner's Avatar
That shouldn't cause an issue unless they used excessive amounts.
.....it will make the pan tougher to get down next time though.
BeMiceElf
Oct 10, 2015 09:40 PM
Poncho0206
Jul 10, 2015 06:21 PM
shar
Jul 9, 2015 12:38 PM
madxman21
Jul 9, 2015 10:26 AM
