Anything to worry about ? (Rust and steering)
Old Dec 11, 2018 | 05:08 PM
GodwinAustin's Avatar
Got a pretty clean 04 I just bought but when going through the engine bay , I noticed the plate at the end of the steering arm is looking pretty bad. This truck is still under warranty. Anything to worry about here?
Old Dec 11, 2018 | 06:33 PM
MistaMota's Avatar
Mine isn't that bad. I think it's location gives it a lot of stone/ pebble pick up from the road which then knocks the paint off... if its under warranty like you mentioned I'd see if they would replace it.. I'd rather have new then old
Old Dec 12, 2018 | 03:07 AM
What IS that part called. I pulled the steering on my 82 before but this is different ...
Old Dec 12, 2018 | 03:17 AM
Also , at first I’ll thought the plate was bent there, but on closer inspection it seems like it is supposed to be bent like that and there are a couple centering pins there instead of bolts?
Old Dec 12, 2018 | 06:53 AM
Malcolm99's Avatar
That is normal, no warranty coverage for that, I call it the rag joint, you might want to spray it down with something, i use undercoating, (but excessive oil is bad for soft rubber), incase you plan on doing a body lift or anticipate your going to change the steering rack. I just separated mine the other day to put the 1" BL in after 20 years on a 99' that sees winters, And it is not bent, those "centring pins" are bolts that hold the rubber rag joint to the lower steering rack, and the other bolts hold the rag joint to the upper part of the rag joint.
Old Dec 13, 2018 | 11:52 AM
aowRS's Avatar
What's that bleed nipple for?
Andreas
Old Dec 13, 2018 | 02:23 PM
Malcolm99's Avatar
Clutch Slave cylinder bleeder valve.
Old Dec 13, 2018 | 03:21 PM
aowRS's Avatar
Ah, I saw 2004 and was confused - as 4Runners went all automatic in 2001. Must be a Tacoma then.
Andreas
suzukipro
10
Jun 23, 2008 08:34 AM
co4rnr
Jun 28, 2007 09:31 PM
KevyWevy
Dec 2, 2003 04:40 PM
Los Gatos?
May 26, 2003 09:29 AM
RC51
22
Sep 7, 2002 05:47 PM
