Anyone good with Carbs?
Old May 7, 2004 | 07:09 AM
yigo65's Avatar
After reading thru the haynes manual on high engine idle, it appears there are a few things that could possibly need adjusting. The choke, the carb itself (which at the moment is adjusted as far as it can go), or the dashpot. Has anyone done this before and is it a difficult task?
86 Toyota 2.4l 2bbl original carb
Old May 7, 2004 | 11:33 AM
HaveBlue's Avatar
Did you also check your timing? If your engine is idling high, it could be attributed to timing needing to be adjusted.
There is only one knob that you should be concerned about when adjusting the idle. It's the only knob on the side of the carb with a "thumb wheel."
Old May 7, 2004 | 11:37 AM
yigo65's Avatar
Yeah just replaced the timing chain and it's where it should be
Old May 7, 2004 | 11:42 AM
Sac State's Avatar
"Anyone good with Carbs?"
I love a big bowl of pasta!
skoti89
Sep 11, 2015 07:46 AM
keithporter83
Jul 24, 2015 07:37 AM
Yota.Jay
Jul 23, 2015 08:08 PM
daddio
Jul 18, 2015 10:20 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
