Anyone ever seen one of these before?
Old Mar 6, 2011 | 10:23 PM
ToyoTech559's Avatar
what do you guys do about the oil. being sideways, straight up or upside down, you loose oil pressure and nothing returns to the sump
Old Mar 7, 2011 | 04:45 AM
mt_goat's Avatar
I've heard of oil starvation from running extreme angles. The oil pick up can start sucking air. I do worry about it sometimes climbing or descending very steep trails. A no sump system or an oil accumulator would be possible solutions. An oil pressure warning buzzer would probably help out too.
Old Mar 7, 2011 | 05:02 AM
irab88's Avatar
Originally Posted by Singtoe
Direct LPG injection is the best route. Using a mixer (carburetor) is pretty inefficient. Power wise and fuel mileage wise. What are you driving, a forklift truck?
Here is a link for Direct LPG injection -LPG Conversion
Using this system is awesome. You have the ability to switch between LPG and Gasoline at a push of a button. The Factory ECU is used with it so none of the check engine lights come on. Lpg is much kinder to your engine. Engine oil lasts 10k miles easily.
Bring it back to stock is just as easy. Just remove system and plug everything back to its original configuration.
There is a power loss when switching to LPG. Propane has about 10% less btu value then Gasoline so it will reduce the power by that much. But LPG carries a higher octane rating ( about 100 or so) so a turbo or super charge will accommodate the loss.
Originally Posted by mt_goat
So would that be better for converting than just doing something like this?
dale or singtoe-- where did they get the kit/parts for this? i've searched, but everything i've seen comes from overseas. if that's where i need to get it, well then, ok
also, do you happen to know if i can use all the same parts as the "carb'd" mixer, just swapping in the injectors?
the carb'd mixer set-up seems very straight-forward, just wondering if i could swap from one to the other with relative ease
Old Mar 7, 2011 | 05:54 AM
mt_goat's Avatar
I copied that pic from here: http://www.ttora.com/forum/showthread.php?t=42524
Old Mar 7, 2011 | 06:39 AM
  #25
irab88's Avatar
yeah, i read all that. thanks. i just didn't know if you had found out. not too much on where they got it from, though. i contacted the place that singtoe linked, but have yet to hear back.
thanks anyway
edit- i just read through again ... the source is posted. $$$, though. the kits overseas are cheaper than that, even with shipping (i assume)
Old Mar 7, 2011 | 06:42 AM
  #26
mt_goat's Avatar
thanks anyway
Didn't you see this post? http://www.ttora.com/forum/showpost....5&postcount=28
Old Mar 7, 2011 | 06:53 AM
  #27
irab88's Avatar
yup. i went back and read it again. there it was
They are cheap overseas. The ones have seen here are super expensive.
If you are going to use Propane, invest in a smart system - Propane injection. Mixer system is easy to install but poor performance and fuel milage.
FWIW - You can put a mixer system on a Modern fuel injection system. There is ventori throat you install upstream of the throttle body and this is where the propane is introduced in the system. Before Propane injection came, everything was mixer based and my buddy would make (turn on a lathe) the ventori bodies and install proane mixer into any car.
^^ those ventori's are nice! too bad i don't have a lathe.
thanks for the info. i'll see if i can't order something from europe... if they ever get back to me . it just seems so ridiculous that they cost $1000+ here, and less than $200 over there
