Any 22Rs come with a tachometer?
Old Jul 26, 2003 | 04:51 AM
jx94148's Avatar
If so what's the redline? Input from 22RE drivers will be appreciated also.
According to this site. I'd be at 4288 RPM at 65 in 3rd gear. I don't go above 60 in 3rd on steep highway grades, but i'd like to know how close I am to the redline when I do that.
Thanks.
P.S. I have 4.30 gears, the closest estimation on that link is 4.27.
Old Jul 26, 2003 | 05:26 PM
toyota parts dude's Avatar
22r redline
my 81 4x4 with a 22r i use for a dialy driver is a SR5 model with the tach in the instrument cluster and the redline is 5500 rpm.
Old Jul 26, 2003 | 05:29 PM
Plays_with_Toys's Avatar
I set my warning thing at about 4200RPM, I went ahead and took the car up to 23mph, and then set the needle a little lower than where it was reading. The owners manual says not to exceed 25mph in first gear, so thats how I based that decision. Here's a pic, although, in the pic it is higher than it is now.
Old Jul 26, 2003 | 06:11 PM
jx94148's Avatar
Ok. That's kinda useful. Did you guys have that site crunch your numbers?
And Plays_With_Toys, does that odometer say 93900 miles? Did someone disconect the spedo cable for 10 years before you got it? I'm at 206000 now.
Old Jul 26, 2003 | 06:39 PM
kyle_22r's Avatar
my '79 with a 20R has the in-dash tach redline set at 5500. i'm pretty sure a 22R has a 5500RPM redline, while a 20R has a 6500RPM redline(due to the hemi head design)
personally i wouldn't go above 4500
Old Jul 26, 2003 | 07:13 PM
You read correctly. I am the 3rd owner, the first was a mechanic, and he didn't use it much, but took good care of it, the 2nd hardly ever drove it (my neighbor), in fact, I never saw it move, but he says he took it out maybe once a month, 2 or 3 times in winter. And now I have it. When I bought it, it had 78,000 miles on it, and now I am at 94,500. $3,700. The paint is junk, and the bed is rusty, but I have seen plenty with more miles and in the same condition going for about that.
Old Jul 27, 2003 | 05:06 PM
jx94148 i checked my numbers on that site and it seems whey off on how fast you will be going and the rpm's. i agree with kyle 22r that going above 4500 it just makes more niose you don't really gain any acceleration. thats where i usually shift or a little sooner.
Old Jul 28, 2003 | 07:53 AM
MNBOY's Avatar
I have the 22RE, installed an aftermarket tach, and set the red line at 5000. Very scientific approach to choosing 5000 RPMs. I drove around and reved the crap out of the engine. Decided that I couldn't stand how it sounded above 5000, made me think it would start flinging out internal parts any minute.
Old May 30, 2004 | 07:47 PM
Tacoma Dude's Avatar
Just out of curiousity...where'd you get the tach? And how hard was the install?
Old May 30, 2004 | 07:56 PM
toy283's Avatar
FWIW, 22R's with auto trans came with a tach as well. Never could figure hat one out.
Old May 31, 2004 | 11:34 AM
Not sure whose post your referring to, but I got mine from Checkers/ Schucks Kragen for $20, and the install was a cake. The 22r(e)'s have a pre-out for a tachomoter. Its by the starter, its a little green plastic piece that has a black cap on it. Take the cap off and plug the signal wire in. The hardest part was when I wired behind my dimmer switch but wired the wrong side, so when I give juice to the dash lights, my tach dims out, and vice versa. It actually requires a full 12v for proper illumination, so the dimmer switch is a bad idea
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
