Antifreeze smell
Old Sep 5, 2012 | 03:59 PM
FJHammerHead's Avatar
Antifreeze smell
Yesturday, I went to go to work and as soon as I got in the 4runner I smelled antifreeze. The front and rear carpet are bone dry and the smell wasn't coming from the vent. The radiator is full and the overflow was not full nor empty. Does anyone know what else I should check?? Thanks
Old Sep 5, 2012 | 04:00 PM
22repower's Avatar
Hoses in the engine bay leaks can be hard to spot.
Old Sep 5, 2012 | 05:16 PM
vital22re's Avatar
totally a bro
water pump may be starting to fail.
Old Sep 5, 2012 | 05:44 PM
Chimpy's Avatar
Have a pressure check ran on the radiator. Could be a tiny pinhole leak. They can be hard to find. If there is a leak the pressure will run off and show on the gauge.
Old Sep 5, 2012 | 06:47 PM
rworegon's Avatar
Use a mechanics mirror and a flash light looking for the tell-tale red or green crust from the leak. Also, check carefully at the head block interface. Could be a small external seep through the head gasket.
Old Sep 6, 2012 | 02:26 PM
Thanks for all the info.
Steven.m.paulk
Jun 7, 2020 10:45 AM
puddlepirate
Jul 30, 2016 06:29 PM
Buckaroo_Banzai
Sep 24, 2015 07:26 AM
themightykhoner
Sep 18, 2015 02:28 AM
Ott47
Sep 14, 2015 12:09 PM
