Another Help Thread - Parking brake light on 85 runner
Old Jan 14, 2005 | 05:36 AM
MDToy's Avatar
Just took my 85 runner through MD Inspection and failed for a few things - I have fixed everything except the light that indicates the parking brake is engaged. Can anybody help on how to trouble shoot this?
Old Jan 14, 2005 | 05:43 AM
firemedic's Avatar
There are two sensors which turn it on, the brake fluid level sensor, or the parking brake sensor. Check for low fluid, or a "sticking" fluid sensor, which should be in the brake reservoir cap, also check that the parking brake sensor is working properly. If everything checks out, one of the sensors is probably bad.
Old Jan 14, 2005 | 02:47 PM
waskillywabbit's Avatar
I don't even have a sensor hooked up to the MC reservoir and my parking brake light goes on and off as it is engaged. I've removed the whole rear portion as I put an e-brake on the t-case, so the sensor has to be on the front part of the cable or up by the lever in the cab.
Old Jan 22, 2005 | 03:39 PM
MDToy's Avatar
Okay, I checked the sensor that the e brake (manually) releases when the hand brake is pulled - one of the wires was off - i soldered it back and tested with a meter and the sensor works...but the Light still does not! How do I test the sensor in the MC Cap? Also, can I test the brake indicator light by running the two wires from the sensor right to a hot and ground?
Old Jan 22, 2005 | 04:29 PM
Flamedx4's Avatar
Um, are you sure it's not just the bulb? Does it come on when you turn the key on?
MudnBullets
Oct 28, 2018 07:00 PM
Aleeex_u
Jun 5, 2016 06:52 PM
voiddweller
19
May 2, 2016 09:10 PM
miceal383
Jun 29, 2015 12:27 AM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
