AMSOIL Synthetic ATF
Does anyone have a good reliable Internet source for purchasing AMSOIL Synthetic ATF transmission fluid at a good price?
I understand that Amsoil synthetic ATF exceeds the service ratings for Mercon V, ATF+4, Dexron III, etc.
I just installed (finally) my transmission temperature gauge using an Autometer billet manifold and 10mm compression fittings I got from Germany. The sensor is about 6" from the case in the outlet line so the reading should be very accurate. However, with a trans cooler the readings should not go up above 200 degrees which is just fine. I also use Lube Gard additive as recommended by John at IPT.
Manymods,
Consider joining the Amsoil preferred member program. That is your best bet. You will get it at wholesale price. If you'd like, I can sign you up or you can do it yourself via their online form. Email or PM me for details.
bob
bob
Originally Posted by tomstin
I'll second the prefered customer method. As I recall it's $10 for 6 months or $20 for a year. You will make up the $10 on a case of ATF.
BTW, you indicated that you have closed off your deckplate opening --- Why? Your truck is SC'd, but I assume you have done no other fuel or ECU mods, right?
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
mordell
Sep 12, 2015 10:13 AM
