Amsoil Oil Filter for 3.4 Question
Old Feb 29, 2004 | 07:45 AM
ElwayLite's Avatar
I was getting my numbers together for my order and noticed that the oil filter number for my yota is the same as my saturn work car, I thought this was strange, anyone run into problems with any part numbers while ordering from Amsoil?
Old Feb 29, 2004 | 11:05 AM
no problems for me...
Old Feb 29, 2004 | 11:06 AM
Hyperlite's Avatar
Did you try to swap the saturn one with your truck
Old Feb 29, 2004 | 09:41 PM
Mossback74's Avatar
Same filter works on the 3.0 too.
Old Mar 1, 2004 | 09:23 AM
tomstin's Avatar
I use the SDF 34 in my truck. A little snug getting in there but the additional filter area can't hurt.
Old Mar 1, 2004 | 09:41 AM
ElwayLite's Avatar
I think the recommended is the SDF57
Old Mar 1, 2004 | 11:55 AM
tomstin's Avatar
Best guess is the SDF 34 is 20 - 30% larger. Gadget is the one that figured this out.
Old Mar 1, 2004 | 12:12 PM
ElwayLite's Avatar
So the 34 is larger and a tight fit but fits. Thats not a bad idea then I mean more filtration area never hurts.
Old Mar 1, 2004 | 03:48 PM
Gadget's Avatar
Yep, I figured it out, the SDF-34 works just fine. It is exactly the same filter as the SDF-57 except slightly longer. Same threads, same pressure bypass valve and everything else, just more filter area so there will be less restriction to flow, and it will hold more crude before flow it restricted.
Gadget
Old Mar 1, 2004 | 05:22 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
The oil filter on my son's '96 Saturn SC2 is the same one I use on my '00 3.4L.
Old Mar 1, 2004 | 05:31 PM
humanoid's Avatar
Gadget
Gadget:
Will they fit in a '99 Pre Taco?
Old Mar 1, 2004 | 05:55 PM
Gadget's Avatar
Yep, and if you want to order one or some oil, or sign yourself up as a dealer or a preferred customer or what ever, click here:
www.GadgetOnline.com/AMSOIL.htm
Be sure to download and read the Motor Oil Bible.
Gadget
Mulkey's Avatar
What about Napa Gold filters? Would the same situation apply?
Old Mar 7, 2004 | 04:02 PM
tomstin's Avatar
OK, change the filter on my tacoma, forgot to get this picture with the new filter, but this shows the difference between the SDF 57 and SDF 34 Filters
Old Mar 7, 2004 | 04:05 PM
ElwayLite's Avatar
cool!
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
Coreyr384
Jul 10, 2015 11:13 AM
Cplmike
Jul 8, 2015 08:47 PM
