Airbox Mod
Old Jun 13, 2004 | 08:21 PM
jethro's Avatar
Airbox Mod
Well I'm a proud owner of a massive 2.7L 4 cyl.
Needless to say I need some power, I dropped in a K&N Filter but then I got inch bigger tires, so that cancelled out. I read this writeup and it seems fairly simple. I noticed it said for the 3.0 V6 Engine. Can I still do this mod to my 2.7 and will I be seeing any significant power gain? I'll cross my fingers!
Airbox Mod
Old Jun 13, 2004 | 10:02 PM
Maddog's Avatar
You can do it to any car with a air box.Every one here will have there own opinion but for me it its worth a try ,it does help a little with throttle response.
I just drilled out my air box.
Old Jun 13, 2004 | 10:10 PM
keisur's Avatar
plus if you decide later you want to blow the money on a K&N kit, the hole in the box won't matter since you'll be replacing it anyway. but my opinion would be to do the deck plate mod, it's like $10 for all the material and the only diffence is that you have a little more turbulence in the stock intake tube than you do in the K&N intake tube.
Old Jun 13, 2004 | 10:11 PM
Mossback74's Avatar
I think there is room to put a deckplate in on the side of your box
Old Jun 14, 2004 | 08:52 AM
ewarnerusa's Avatar
there is room in the front of a 2.7L airbox for a 4" deckplate. I did it to mine when I had one. I would suggest putting one in the front rather than the side, so that the opening is not pointing towards the engine. check the link for pic.
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
toyotasaurus
Sep 24, 2015 03:30 PM
