Air horn install brought to you by an obsessive compulsive...
Old Aug 21, 2003 | 04:27 PM
4RUNR's Avatar
Guest
Here we go, removed the grille, headlight, blinker, coolant reservoir.
http://www.xshots.com/upload/4RUNNER/01.jpg
The air pump. 12 gauge wires soldered on as any corrosion and poor contact in the future would be a pain to fix. Wires bonded to the body just for neatness and so pulling on them won't damage anything.
http://www.xshots.com/upload/4RUNNER/02.jpg
This is the view from driver side wheel well. The hole was there and not used for anything, so perfect place to mount the pump.
http://www.xshots.com/upload/4RUNNER/03.jpg
Pump mounted under the coolant reservoir. Battery on left, radiator on right.
http://www.xshots.com/upload/4RUNNER/04.jpg
Top view of the horn mounted on a small custom bracket. Wire loom on air hose so it doesn't rub a hole. This is a one horn setup. Two horns had an annoying "buzz/resonance" to them. One is just as loud and low! It's all about placement anyway.
http://www.xshots.com/upload/4RUNNER/05.jpg
Front view. The horn is tilted upward so no water will enter. It is also front firing with virtually no obstruction.
http://www.xshots.com/upload/4RUNNER/06.jpg
And another view from inside the bumper.
http://www.xshots.com/upload/4RUNNER/07.jpg
No drilling involved. Thinking up and the locations took up most of the time. Think the idea is worthy of a writeup?
Old Aug 21, 2003 | 07:04 PM
Cebby's Avatar
Your pics are impersonating a red "x".
Old Aug 21, 2003 | 07:11 PM
4RUNR's Avatar
Guest
Damnit :pat: They show on my end.
Fixed (sort of).
Do the links work though?
Old Aug 21, 2003 | 07:14 PM
turboale's Avatar
Work for me, the pics worked for me too.
NICE install! mine was almost as neat as yours. We didn't even cut the stock harness so I can plug the stockers back in if I want. My set also comes with two settings, one side of hookups are regular blast of both trumpts on. But if powered by the other side then they oscilate. Makeing a euro-police sound. So we made up a little circuit with two relays giving me the ability to switch the horns from the cab. I put the setup in the runner the same time I put the TJM on and the trumpets fit perfectly where the winch goes. I will have to mount them elsewhere when I get a winch, but I have a little while. Nice work!
Old Aug 22, 2003 | 06:06 AM
4RUNR's Avatar
Guest
Curious: how did you interface to the factory harness? For now it’s just in there with some electrical tape around. I didn’t sleep well at all
Old Aug 22, 2003 | 06:14 AM
SLC Punk's Avatar
Looks like a good, clean install!
Old Aug 22, 2003 | 06:48 AM
rimpainter.com's Avatar
Wow, I thought I had OCD!
Very clean. Nice work.
Eggslinger
Jun 8, 2019 03:32 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
coryc85
Sep 9, 2015 06:24 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Jnkml
Jul 6, 2015 01:20 PM
