air/fuel ratio gauge
Old Jun 17, 2003 | 09:24 PM
3.4v6's Avatar
i have an autometer air/fuel ratio gauge and was just wondering if it is supposed to bounce back and forth or just sit still and slowly move.
Old Jun 17, 2003 | 09:31 PM
asudan96Runner's Avatar
Sounds like you do not have a wideband o2 sensor, or a/f gauge. That's okay. In your case it will only be accurate (and should also be stable) at WOT. (Wide open throttle)
What kind of results are you seeing at WOT?
Dan
Old Jun 17, 2003 | 09:53 PM
3.4v6's Avatar
Dan
at WOT only the last 2 green lights(rich) are the only ones lighted up
Old Jun 17, 2003 | 10:42 PM
LD Gear's Avatar
What year 3.4 and just where did you tap into the O2 sensor? the reaso I ask I have one also and it says not to tap into a Shielded wire but the wiring digram I have says the wire going into the ECU is shielded????? Let me know THANKS
Peace Ron
Old Jun 18, 2003 | 07:30 AM
3.4v6's Avatar
Peace Ron
i have a 01 taco. i tapped into the second o2 sensor on the purple wire. how do you know if the wire is sheilded? thanks
Old Jun 18, 2003 | 07:34 AM
LD Gear's Avatar
That is what my wiring diagram says, I don't know if it makes a difference though? Do you have 2 o2 sensors? and why the back one and not the front one? sorry for all the ?'s I'm just not that good at electrical crap...........
Peace Ron
Old Jun 18, 2003 | 09:19 AM
Just fyi, your 2001 has a wideband O2 sensor which is incompatible with your Autometer guage. You will have to either get an old style narrowband O2 sensor off an older toyota, or buy the narrowband O2 sensor kit from autometer and have it welded into your exhaust. gl
Old Jun 18, 2003 | 09:42 AM
3.4v6's Avatar
yea i have 2 o2 sensors. i tried connecting the o2 sensor in the front but it wouldnt work ,i dunno why, the last o2 sensor near the middle of the truck is the one that worked for me.
Old Jun 18, 2003 | 09:44 AM
3.4v6's Avatar
so i can either can an o2 sensor from an older toyota ... how much older?
thanks
Old Jun 18, 2003 | 10:13 AM
cstary's Avatar
Re: air/fuel ratio gauge
yes, it's called "dithering," and it's the result of the system being in a "closed loop" circuit, where the ECU is trying to find the best A/F ratio. it should dither at a rate of at least once every two seconds (0.5Hz).
under heavy (>80%) throttle, the ECU switches into "open loop," and that is where the tuning occurs. with an s/c, the last two lights should light up (A/F ratio of 13:1 to 12.5:1).
creed
Old Jun 18, 2003 | 10:14 AM
cstary's Avatar
it doesn't sounds like he has the newer A/F meter . . . he would be reading a constant 3.3V if he did. sounds like, for some reason, he has a truck with an EGO . . . maybe it was an out-of-state truck?
creed
Old Jun 18, 2003 | 01:11 PM
Yeah I was thinkin that as well...to be honest, I'm not sure how the autometer gauge would react is why I didn't mention it. I'm guessin it would be blank if it's a WB O2...but if it is showing the last two leds at WOT hmm
Old Jun 18, 2003 | 01:44 PM
cstary's Avatar
the AM guage is just like SS gauge . . . a series of LED's with different in-line resistors, that light up at particular voltages in the 0-1V range, which is what the output of the EGO is. you could get by with just a voltmeter to tune with if you wanted.
this is for the SS guage:
http://www.splitsec.com/products/arm1/arm1ds.htm
creed
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
dbollier123
Sep 29, 2015 05:23 PM
Odin
Sep 26, 2015 06:56 PM
