Air Flow Meter HELP!!!!
Old Sep 23, 2003 | 05:54 AM
TRunner's Avatar
Exclamation Air Flow Meter HELP!!!!
I know a couple of you have mentioned that you have replaced these on your truck. What were the symptoms of this failing? I recently had a bad head gasket and had to replace a bad O2 sensor, but now my engine is running rough and it gets bad milage. The problem seems to fade in and out, but it is more rough then not. I get a check engine light with the lean message (25).
What more can I go on to figure out this problem?
If it is an AFM where could I get a good cheap one? Would a junk yard safice?
Old Sep 23, 2003 | 06:04 AM
TOR
Mass Air Flow
Well on the O2 problems I would recommend taking it to a good shop for diagnosis. As for the MAF I would not get anything like that out of the yard for my truck. Don't know if your truck is 4 or 6 but the price would be the same either way through me, $425.98 to your front door.
Todd
Old Sep 23, 2003 | 06:33 AM
TRunner's Avatar
Re: Mass Air Flow
The O2 problem is no more and I don't know if I do need to get a new AFM, yet. But that is the best price for a rebuilt/new one that I have seen. I'll let you know.
Old Sep 23, 2003 | 06:36 AM
TRunner's Avatar
Todd
BTW - I got the brake booster out of a junk yard for $80. Thanks for woking with me on the price of a new one, but I could go through 8 of these before I hit the price of a new one. And since mine lasted 175,000 miles and you never hear of them failing, then I figured I would be safe to give it a shot.
Old Sep 23, 2003 | 07:04 AM
mtnfreak's Avatar
This is a little weird, but after I replaced my O2 sensor, I started getting codes 25 & 26. I replaced the front shocks and the check engine light hasn't come on since. Go figgure.
Old Sep 23, 2003 | 07:28 AM
TRunner's Avatar
hmmmm.... I do have a rear shock that is out. I was waiting untill I fixed this problem and then I was going to do the spring job and rear shocks. Maybe that *is* the problem.... hmmmm......
Old Sep 23, 2003 | 08:37 AM
cstary's Avatar
i've run used MAF's from yards before with no problems.
might be worth it to spend $50 on a used one before spending $500 on a new one.
creed
Old Sep 23, 2003 | 08:46 AM
TRunner's Avatar
twas what I was thinking.... Most all 4Runners that are in junkyards were not ran into the ground. They were totalled by drunken teenagers and soccer moms.
Old Sep 23, 2003 | 08:53 AM
TOR
Maybe yes, MAYBE NO!
Todd
Old Sep 23, 2003 | 09:00 AM
rimpainter.com's Avatar
Why dont you get a new VFM from Autozone, then return it if that is not the problem?
Old Sep 23, 2003 | 11:20 AM
TOR
MAF
You don't need no stinkin MAF!
Todd
Old Sep 23, 2003 | 11:21 AM
C'mon Todd, we're all perfect here. Let's get with the program!
Old Sep 23, 2003 | 11:44 AM
TOR
MAF
I guess you're right Christian. Ok Mr. you need a whole short block assembly!
Todd
Old Sep 23, 2003 | 11:56 AM
TRunner's Avatar
Todd's giving away free short block assemblies!!!!
Old Sep 23, 2003 | 12:13 PM
TOR
free shortblocks
Yeah why not? God knows we aren't doing that much business today.
Todd
Old Sep 23, 2003 | 12:22 PM
Robinhood150's Avatar
$425 is the best price I've ever heard on an AFM.
There are electrical tests you can do to determine if the AFM is bad, check chiltons or a FSM. Oh, and I think somebody outlined the procedure here...do a search for that. FWIW, the dealer told me it's very rare for an AFM to go bad so a junkyard one might not be a bad way to go.
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
rjtrials
Aug 6, 2015 07:25 PM
bighaydn
Aug 4, 2015 07:17 PM
