AFM Mod
Old Jun 5, 2003 | 02:34 PM
AFM Mod
I have been looking for an old thread that talked about changing the AFM on the 3.0 for better airflow, I can't find it.
SO I am going to start it up again.
Is there a way to open up the AFM in the 3.0 for better airflow? I have heard about getting one from the SUpra, but not sure about that.
Any Opinions?
Old Jun 5, 2003 | 02:49 PM
HaveBlue's Avatar
The only AFM swap I have heard about was performed on a 3.4L. The person who performed it was Gadget.
Also, doesn't the 3.0 use a VAF? Or am I full of @#$%?
Old Jun 5, 2003 | 02:50 PM
Dr. Zhivago's Avatar
Away
I'd do the ISR mod for the 3.0, along with the Airbox mod. That AFM should flow more than enough air for that engine.
My .02
Dr. Z
Old Jun 5, 2003 | 02:51 PM
Away
It is a Vane Air Flow Meter. You 're not full of #$@%.
Dr. Z
Old Jun 5, 2003 | 05:04 PM
PirateFins's Avatar
The supra afm is for the 22re. The afm from a 82 supra is a dirrect fit plug and play into a 22RE. Can't be of any help for the 6cyl.
Old Feb 26, 2007 | 09:00 PM
co4rnr's Avatar
I feel so bad today b/c I "tried" to clean what I thought was my MAF and pulled out the connections for the AFM. WHile it is torn apart right now, and before I try fixing it, Would the MR2 AFM give me more performance? Where can you get something like that. I am curently living in Denver at about 6000 feet elevation. What is the best course of action?
Old Feb 26, 2007 | 09:01 PM
Elton's Avatar
holy old thread geez its almost 5yrs old
Old Feb 27, 2007 | 04:56 AM
MTL_4runner's Avatar
Is this on a 3.0L with an AFM?
If so, you're not the first person to do that.
Old Feb 27, 2007 | 05:28 AM
co4rnr's Avatar
No, it is on my 22re. I am going to try and solder the conections back together. While I have the black cover off of the top, would ya'll advise adjusting it to run leaner because I live at a higher altitude?
Old Feb 27, 2007 | 06:00 AM
mt_goat's Avatar
Been there, done that. It takes a steady hand and a small pointed soldering tip with thin solder. Make sure the solder doesn't cross the tracks. Good luck.
TheBFA
Feb 15, 2020 06:55 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
toyotasaurus
Sep 24, 2015 03:30 PM
