Advice Wanted on Timing Belt Pictures
Old Jun 3, 2010 | 08:36 AM
TheDurk's Avatar
Originally Posted by jbudhram015
Pulled the trigger and got the belt, water pump, idler and tensioner bearings replaced. Drive belts were all good as were the cam/crank seals. Got it done at TOS in Sacramento for $805, picking it up tomorrow, will post again when I get to hear it run etc.
I love these posts: means I saved $500+ doing it myself. I don't know about saying drive belts are 'good'. Just because they look fine, if you don't KNOW their age, and you are doing a TB/WP for $805, why would you NOT change them for another $60 or so if you are keeping the truck a while? The original ones I took off at 120K LOOKED fine, although alt. belt WAS starting to squeak even though it was tight.
I agree on leaving the seals if there is no sign of trouble. I bought them just in case, but didn't put them in.
Old Jun 4, 2010 | 10:09 PM
jbudhram015's Avatar
The belt and water pump would have been around $550, it was $800 for the belt the pump and both bearings, I said that in the post. After getting to drive the truck a bit it's quite a bit more smooth sounding at idle most likely because the bearings that were pulled were bad. The water pump was leaking so all in all everything that got replaced was due. I was really happy with the service and if you are in the Sacramento area I would really recommend TOS I have some cards that give some discount on service for referrals if anyone is interested. The guy I dealt with was Tom.
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
layifioren
10
Jul 6, 2015 02:26 PM
marcusSRG
Jun 27, 2015 07:13 AM
infinityisfive
Jun 16, 2015 06:51 PM
