Adjusting headlights on 3rd gen
Old Jun 27, 2003 | 08:38 PM
Andrey's Avatar
I have '01 4Runner SR5 and after the lift it seems that the rear is a bit higher, so headlights point right in front of the truck, not in the distance.
Would anyone know which screw I need to turn to make the beam from my headlights to go a little higher and farther in the distance? And what is the easiest way to get to that screw?
Thanks in advance!
-- Andrey
Old Jun 28, 2003 | 02:47 AM
WT's Avatar
WT
I recall reading some were they were none adjustable on 3Gens, someone correct me if I'm wrong.
Old Jun 28, 2003 | 08:52 AM
pfdaxe's Avatar
You can adjust them. I adjusted mine after installing my HIDs. There's a plastic screw on the side and top to make the adjustment. Pick up a Haynes repair manual and it shows you how to adjust and what the screws look like.
Old Mar 4, 2009 | 07:33 PM
data's Avatar
Senior Member
Bumping up an old thread...
I couldn't find the screws they were talking about...maybe I'm dumb..haha
Old Mar 4, 2009 | 07:54 PM
Rock Slide's Avatar
Data, hope this helps. Just copy the below link and paste it in your address bar:
http://www.toyota-4runner.org/showthread.php?s=&threadid=39701<br />
Old Mar 4, 2009 | 08:52 PM
Scottiac's Avatar
be careful adjusting those little plastic teeth. I thrashed mine badly enough I had to replace the headlights completely. (*OUCH*)
The dealers can do it for pretty cheap but bring the DOT instructions for aiming headlights with you. I had to go three times before they got it right. (And I was hella pissed by the end of it!)
Old Mar 5, 2009 | 05:45 AM
data's Avatar
Senior Member
ah sweeeet! Awesome! Thanks guys!!!
Old Mar 6, 2009 | 11:50 AM
surf4runner's Avatar
spray lube on em before adjusting, help me.
jerusry
Oct 19, 2015 05:28 PM
snap-on
Aug 10, 2015 05:19 PM
mldave
Aug 10, 2015 09:23 AM
ChiefTetlow
Aug 10, 2015 04:19 AM
rushw
Jul 18, 2015 01:46 PM
