ABS light on with new LED tails...
Old Aug 19, 2009 | 08:29 AM
Yotacool's Avatar
I have the same problem! I know this is an old thread, but, just to be correct, you need to buy the 6 ohm load eqaulizers. One for each side, and run them from the power wire to the ground wire right?
Also, does this make them dull?? I know 6 ohms isn't much, but.... curious!!'
thanks
Old Aug 19, 2009 | 08:38 AM
4Crawler's Avatar
thanks
The load resistors are put in parallel with the LEDs so have no impact on the current through the LED, so they are the same brightness. I made mine to plug into the trailer wiring connector while I ran the resistors.
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
JHalcyonM
Aug 4, 2015 01:19 PM
ty1er
Aug 1, 2015 11:53 PM
Esibnitsud
Jul 30, 2015 08:21 PM
