abs light
Old Aug 13, 2002 | 03:26 AM
astein34's Avatar
abs light
I just purchased a 4runner and the rear abs light is on. The brakes seems to be working OK though? Anyone have an idea what it might be or at least how to check the error codes.
Thanks,
Drew
Old Aug 13, 2002 | 05:01 AM
peterbilt's Avatar
Drew,
Not sure I understand a rear ABS light. I thought there is only one ABS light on the dash. Can you be more spaecific? What year is your truck, you didn't say whether you bought it new or used?
Anyway, welcome to the forum Drew.
Pete
Old Aug 13, 2002 | 05:03 AM
UKMyers's Avatar
Hey Drew what year is your truck?(Edit) I guess pete beat me to the post about the year. BTW welcome to the board! Sometimes the manual will give you a trouble shooting guide on that kind of stuff. Sorry if I insulted your intelligence if you have already looked their. Good luck with your fix, hopefully it's something simple!
Old Aug 13, 2002 | 08:38 AM
rchavis's Avatar
Welcome to to board.
I have a 92 and it was the speed sensor switch. Dealer cost and installed for $185. The speed sensor switch is located in the axle as I understood it, could be wrong. Anyways have fun with your toy.
Old Aug 13, 2002 | 11:16 AM
astein34's Avatar
Thank you for all the welcome in's. The truck is a 93 v6 4x4 I had also heard that it could possible be the rear speed sensor. Also the light only says abs I just said rear abs because it only has ABS in the rear. If anyone has any other ideas I will look into those too. Until then I'll try to find this rear speed sensor.
Thanks again, and I'm sure I'll post a lot more things here over the years.
Drew
Old Aug 13, 2002 | 11:30 AM
Hbum's Avatar
Welcome to the board.
Somebody needs to tell Drew how to read the codes. Then he will know what is making the computer unhappy. I have a third gen so I'm no help.
Old Aug 13, 2002 | 11:36 AM
astein34's Avatar
One other thing
How do I get a picture of my truck on the left with me name.
thanks,
drew
Old Aug 13, 2002 | 12:08 PM
UKMyers's Avatar
Drew if you click on User CP at the top of the screen and then click change options you will see the Avatar stuff at the bottom of the page. Click on change avatar and you will be able upload a pic right off your PC. Only catch it has to be 120X120 pixels. Good luck!
Old Aug 13, 2002 | 01:16 PM
Toyota Punk's Avatar
Check your brake fluid. I had the ABS light going on sparatically on my 94, until it finally went on and stayed on. I can't remember exactly how I came upon it, but it turned out to be that the brake fluid was low. Much cheaper than a speed sensor, hopefully it's just that.
Old Aug 13, 2002 | 08:36 PM
astein34's Avatar
Brake fluid is perfect. That was the first thing I checked.
drew
Old Aug 14, 2002 | 02:31 PM
RWD
I have a 93 T-100 4x4 and had the same problem 2 months ago. The light would come on after driving it for 10-20 miles. When cold, first thing in the morning, it was fine. Turns out it was the sensor in the rear axle. I don't know how to check for codes but I'll tell you what I did. I pulled the connector to the sensor and used a ohm meter to check the sensor for continuity. When hot (after a few miles driving) the sensor was was not workin (meter didn't move) When cold the meter registered a complete circuit. Simple job to replace, just one bolt in my case. Sensor was about $100. HTH, Bob
AkitaDog
Sep 1, 2015 08:05 AM
JimiJams
Aug 7, 2015 01:36 PM
sqdg71
Aug 7, 2015 01:03 AM
ty1er
Aug 1, 2015 11:53 PM
87turboPA
Jul 12, 2015 07:49 AM
