99 tacoma rear sagging
Old 11-23-2010, 06:28 PM
kenstoy's Avatar
I just put a cap on my truck for hunting season and hauling my gear around but it feels like i am hauling a ton of junk in the back,is there anything i can do to help this problem or any suggestions you guys have to get my truck to ride level again,thanks ken
Old 11-23-2010, 09:26 PM
scuba's Avatar
Get an add a leaf.
Something like this..
"Wheeler's 1.5" Lift 3 Leaf Progressive Add A Leaf Kit"
http://www.wheelersoffroad.com/9504tacoaal.htm
Old 11-24-2010, 08:08 AM
profuse007's Avatar
simple airbag will fix the problem. airlift 1000 or firestone coil rite.
the air bag is placed inside the spring. no pump or air tank is needed. the air is fed through a hose w/ shrader valve.
Old 11-25-2010, 12:02 AM
awdjunkies's Avatar
How about an OME Rear Suspension Lift?
Old 11-26-2010, 11:31 AM
Mr.B's Avatar
tacomas got leafs, not coils id say just slap in an AAL.
Old 11-26-2010, 12:06 PM
maniacmotorsports's Avatar
I have a set on my 1 ton flat bed yota that you bolt a bracket on the frame rail and bag mounts on top of the spring perch. Bought them from summit a few years ago for $70. I have put 3000lbs of wet sand on the back of that 'ol girl.
Old 11-26-2010, 12:09 PM
Mr.B's Avatar
ooooh... rajah, rajah. so does that replace the factory bumpstop on the leaf springs? or replace the leafs all together? im slightly confused...haha, got two different mental pictures in my head. you got any pics of it on the ride?
Old 11-26-2010, 12:12 PM
cut off the bumps, they have a plate that gets clasped under the u bolts where the stops were
Old 12-01-2010, 04:06 PM
kenstoy's Avatar
thanks for the replies,i checked out a few different ideas and i think im gonna put on the air-lift level control,its about 205.00 dollars did some research and next week im going to get my early christmas present lol i will let use know how i do with the install thanks again,ken
Old 12-11-2010, 08:17 PM
kenstoy's Avatar
installed the air lift today on my truck it was pretty easy to do and what a big difference it makes in the ride wow ,it rides like a new truck again,i will post some pics tomorrow,thanks again for the replies, ken
Old 12-11-2010, 09:56 PM
Pool Playen Bob's Avatar
most defiantly man. i wanna see some pics of that sucker installed. its got me curious on how its all said and done in there.
Old 12-15-2010, 03:17 PM
kenstoy's Avatar
trying to get pics up but having trouble posting them bare with me lol any help appreciated thanks ken
Old 12-15-2010, 04:08 PM
survivorman97's Avatar
Here is another thread on the same issue.
https://www.yotatech.com/forums/f2/w...s-help-209792/
Old 12-16-2010, 05:59 PM
kenstoy's Avatar
you should check out the air lift as soon as i get pics up you can see the install and it is like night and day with the ride,and best you can adjust it anyway you want, its cool
Massmayhem247
07-18-2015 05:46 AM
rondogracing
07-14-2015 07:00 PM
akaphilly
07-09-2015 02:18 PM
Nickdigg
07-07-2015 06:04 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 99 tacoma rear sagging
