Intermittent squeeling???
Old Feb 14, 2004 | 10:17 AM
Plays_with_Toys's Avatar
Question Intermittent squeeling???
Recently colorado dipped into the negatives. I have never had my car in such cold weather.
The day that happened, I let the car warm up, which took alot longer than normal. Anyway, while driving I would hear a squeeling, it wasn't very loud, but almost like a bad belt or something. The squeeling isn't bad until 2200 rpms or more. I thought it would go away after it warmed up around here, but its now in the 50's and I am still getting the squeeling.
What could be the problem? Does extreme cold do something to the belts? Is there is somewhere else I should look? Also, I did replace the idler pulley bearing, but it was just a run of the mill bearing, do you think maybe the bearing wasn't designed to get that cold and now [i]it[i] is the thing squeeling?
Thanks for the help!
Old Feb 14, 2004 | 10:51 AM
chasmc2's Avatar
I have a squeling that comes from my speedo cable. it is bad when the weather gets cold. mostly here in the colorado area. good luck finding it. if its the speedo cable I have done everything except replacing it. now i just turn up the Stereo
Old Feb 14, 2004 | 11:53 AM
85runner's Avatar
It could be the throw-out bearing also...but if it was, the noise would change when you step on the clutch.
Old Feb 14, 2004 | 12:04 PM
barkeywayne's Avatar
I was getting some intermittent squealing in one of my 22R trucks, totally random, over the span of several months. I finally pinpointed mine to a bad alternator bearing, it would drag a little and make the belt squeal. Replaced the alternator (it was shot anyway) and that cured it. Good luck on finding your noise!
Old Feb 14, 2004 | 06:32 PM
Not the throw out bearing, just had the entire clutch replaced with bearings back in october. When I listened to it, it sounded like it was coming from the passenger side headlight :wtf:
Strange though, because while the sound was evident yesterday, it never squeeked once today. I will see if it makes sound these next couple days.
Old Feb 15, 2004 | 09:20 AM
85runner's Avatar
Does the truck have AC?
Old Feb 15, 2004 | 10:48 AM
No it doesn't have AC.
I am thinking it is the idler pulley bearing. I think because it is a generic bearing, it isn't designed to go that cold, so some of the oil in it probably got too thick and now that its worked through it with some warmer temps, its gone away.
If it does come back, I will look at the alternator (god I hope not, I've spent nearly $1500 on this thing in 4 months).
Thanks for the replies!
Old Feb 15, 2004 | 07:24 PM
HaveBlue's Avatar
Hey, Dan-
It sounds like either a belt or an alternator bearing. The belts on my '83 squeel pretty bad. I need to replace them. When I had a Honda Civic as a commuter, the alternator bearing gave up. It squeeled until it warmed up, then it would just buzz. In your case, since it's RPM related, it would probably be the belts. Spray a bit of belt dressing on them and that should quiet them down until you replace them or tighten the tension.
Old Feb 15, 2004 | 08:56 PM
scubasteve83's Avatar
Banned for dupe accounts
Hey goodtimes though. Let me know if you ever need help workin on that truck of yours. Good luck with that squeel my speedo cable makes a rattling noise. Its nnoying but the radio covers it up.
<~~~~Still love that pic!!!!
Old Dec 17, 2010 | 07:57 AM
86bedlesstoy's Avatar
Nice so buy a idler pulley and alternator.. hmmm
puddlepirate
Jul 30, 2016 06:29 PM
jacked_72
Sep 14, 2015 03:31 PM
Duppie007
Aug 31, 2015 07:04 AM
zeflower
Aug 30, 2015 06:52 AM
landrunner
Aug 5, 2015 09:18 PM
