99 Tacoma 4x4 3.4L stalls/unresponsive at 3000 rpms
Old Jul 8, 2011 | 06:36 AM
PLowe's Avatar
I'm having a problem with my Tacoma not responding or stalling when the rpms reach approximately 3000. If I hit the gas around 3000rpms it sputters and acts as if airflow or something has been cut off? I'm not getting any error codes and the check engine light doesn't come on? If I keep the rpms under 2500 the truck runs fine. Does anyone have any suggestions? I have taken it to get a diagnostic machine reading at Autozone and no error codes as I stated earlier. Thanks for the help! By the way I have a manual transmission.
Old Jul 8, 2011 | 04:14 PM
J2F42C's Avatar
Have you ever replaced the catalytic converter? You may need to to resolve your problem.
Old Jul 8, 2011 | 05:06 PM
rworegon's Avatar
Check all the vacuum hoses and air intake tube for cracks or one that has slipped off its fitting.
Old Mar 1, 2012 | 08:24 PM
laloosoria's Avatar
04 tacoma stalls when acelerating
hey guys!! I´m having this issue with my tacoma, its an 04 with the 3.4L and stalls when i press the gas pedal like at 15%.....if i step quick on it it works fine but when i´m depressing it and pass thru that ´´ 15- 20% ´´ it stalls again.... looks like that spot cut off the ignition. I´ll thank any suggestion.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
