99 Runner automatic trans fluid.... which type?
Old Oct 25, 2010 | 06:19 PM
sharrack's Avatar
What standard AT fluid are you using in your 99 4runner automatic V6 ?
Kenny S>
Old Oct 25, 2010 | 07:34 PM
pendrag's Avatar
Castrol Dextron VI
Old Oct 26, 2010 | 05:43 AM
hurricanes99's Avatar
Manual calls for Dexron III. I have been using Castrol High Mileage, but plan on switching to AMSoil universal ATF in near future.
Old Oct 26, 2010 | 07:53 AM
CYi5's Avatar
I flushed for the AMSoil synthetic ATF recently.
Old Oct 26, 2010 | 09:24 AM
J2F42C's Avatar
If $$$ is not a deciding factor, the Amsoil ATF, Eneos, or Redline D4.
If $$$ is an issue, Castrol Import Vehichle ATF worked well for me for 30,000 miles until the switch to Redline.
The only one I would be wary of using is the new formula Maxlife ATF. It made my buddy's A343F start slipping after a month. So far on a change to Castrol Import and 7,000 miles since the flush, it has had no more problems.
Old Oct 26, 2010 | 12:25 PM
Smokey's Avatar
2002 running Valvoline Max Life DEX/MERC ATF with no issues. If you search the Internet (bobistheoilguy.com is a great site) you will find that this ATF is great quality for the money. I did the dilution method (dump the pan and refill) a few times over the course of 1-2 months to get the old stuff out.
Oh, and I have 134,xxx miles on the clock.
Chris
Old Oct 26, 2010 | 05:19 PM
J2F42C's Avatar
Eating crow here...
Spoke with my friend with the A343 tranny a couple of hours ago, one of his solenoids bit the dust for his Cruiser. So it probably was not the Maxlife after all. Add it to your list of candidates.
As Smokey said, the BITOG folks do love it, even for T-IV applications:
http://www.bobistheoilguy.com/forums...39#Post2058539
Old Oct 26, 2010 | 05:25 PM
oregon taco's Avatar
i just run the napa generic. but then again i flush it every three thousand miles. so maybe that doesnt count?
Old Oct 26, 2010 | 05:47 PM
brian2sun's Avatar
3K is nothing for ATF, that's overkill and then some. And you're flushing it too? That takes like 12+ quarts! You could be saving a lot of $$ and go 10xs longer - to 30K intervals and still be safe and within recommended service.
Old Oct 27, 2010 | 11:51 AM
Mtn Mike's Avatar
After doing some research here and on BITOG, I'm using T-IV, which is the same as the Mobile 3309. It's made for our transmissions, apparently. I'm on my second batch of it since owning the 4R. Things seem to be working fine.
Old Oct 27, 2010 | 01:53 PM
longroad's Avatar
I did find this TSB a while back when looking at the same thing, I'm not saying it would be harmful as I think IV is a better fluid, just passing it along.
Old Oct 27, 2010 | 02:44 PM
sharrack's Avatar
I used 12 qts of castrol import car trans fluid.
I have another lube issue:
90w for my 99 runner rear diff is hard to fond in any store. Napa sells quicksilver
90w gear lube for lower mercruiser units. Marine grade. Is this ok for my rear diff??
Thanks, kenny S
Old Oct 27, 2010 | 07:29 PM
J2F42C's Avatar
Thanks, kenny S
The thicker 90wt, marine or not, may hurt the MPGs. I would not use the marine unless you are exposing the differential to many deep water crossings. That said, I knew a boat dealer in SC who ran nothing but GL-4 oil in his Ford diffs and had zero problems with them.
Go back to Napa and tell them you want the Valvoline Durablend 80w-90 since Napa is a full Valvoline liquids retailer.
Old Oct 28, 2010 | 08:03 AM
sharrack's Avatar
So 80w 90 is ok to use in the
Rear diff of my 99 4wd runner.
I should have no problem
Finding that. Thanks
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
Steezy96yota
Jul 6, 2015 10:00 AM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
