99 runner - alarming lower control arm issues
Old Dec 9, 2009 | 11:09 AM
mt_goat's Avatar
Originally Posted by cpizzle42
I dont know if I would trust a non oem LCA, just my .02
I wouldn't either. I say buy a salvaged control arm and replace the bushings if it needs it, then swap it and sell your old one to someone else to refurbish. That cuts your down time. The bushings can be pushed in and out with a big vise like this one but it takes a long cheater bar on the handle:
I did a small write-up somewhere on replacing them.
EDIT: here it is: https://www.yotatech.com/forums/f116...cement-152186/
Old Dec 9, 2009 | 11:11 AM
DeathCougar's Avatar
hahaha alright cougar you win bud. You go ahead and install mile'd out equipment.
So you would use aftermarket bushings, but not aftermarket arms. Interesting.
I think I fairly well represented the fact that low mileage, good quality used arms are available. That does not make them "Mile'd out" Everyone is entitled to their own opinion. Yours is not incorrect, but I feel its unfair to condone used parts so quickly. With that thinking, every car should be sent straight to the crusher because "no one knows the condition" of the parts.
Originally Posted by sharrack
Godzilla's idea sounds like the best one IF the bushings are included with the
LCA's.
It specifies including the lower ball joint so I'm questioning the bushings being included.
Otherwise I'll go that way.
Kenny S>
New control arms come complete with new bushings.
Toyota part numbers are:
48068-35081 Pass side
48069-35081 Drivers side
Old Dec 9, 2009 | 01:12 PM
hross14's Avatar
Not to change the subject--but while i have you on the "phone" Cougar--do you know which body mounts work for which years--I need to replace mine (1999 4runner, 5Spd, 4x4) and there are alot of Cash for Clunkers in the Local Junkyard.
Now back to it--coug is right--used parts doesnt mean they are crap---However, considering you can get new OEM LCA's for so cheap WITH new ball joints--thats fargin sweet deal.
In a pinch I wouldnt mind used parts....
Old Dec 9, 2009 | 02:31 PM
BajaRunner's Avatar
Heh I've needed new LCA busings and ball joints for nearly 3 years now. Before I lifted my truck, I had no issues. As soon as I lifted and put larger tires on it, I started having really bad issues.
I talked with a guy who had just done the new control arm bushings, and said it was a royal PIA. Basically don't do it yourself, and the guys at the shop will probably charge quite a bit because they are such a bitch to replace.
Basically what I have gathered online and from people, its a lot easier to buy used LCA's with decent mileage than deal with the bushings themselves.
Old Dec 9, 2009 | 03:36 PM
  #25
*edit* According to T.P.S. the control arm DOES include the ball joint
Old Dec 9, 2009 | 06:39 PM
  #26
aowRS's Avatar
Originally Posted by DeathCougar
Where do people see that they include ball joint? New OEM arms do not, and ball joints are $105 list from Toyota.
Post #17 mentions toyotapartsales.com. Go though their parts catalog and you'll see that the LCA comes with ball joint, and is priced at $174.
Andreas
Old Dec 9, 2009 | 06:46 PM
  #27
Godzilla's Avatar
Andreas
werd...
Link
toyotapartsales.com is just fantastic
Old Dec 9, 2009 | 08:59 PM
  #28
OIC...well, proven wrong.
The Mitchell catalog I have doesn't show the ball joint as part of the arm.
If that price is indeed with the lower ball joint, that is a screaming deal!
Old Jan 5, 2010 | 07:09 PM
  #29
sharrack's Avatar
Well...............you knew it would come down to $$$$$$$$$$$ in the end.
The LCA complete were just too much money with shipping so I went with the
LCA bushing set from toyotapartssales.com.
Saved about 35.00 over the stealer price.
Still ridiculous at 40 bucks each!!!
So .......a big vice, some plumbing fittings and some busted knuckles are in my future.......
Luckily , I have a second vehicle and I'll only do one side at a time.
Kenny S>
Old Jan 6, 2010 | 04:13 AM
  #30
mt_goat's Avatar
Don't forget the 3 foot cheater pipe, BFH, and PB blaster.
Old Jan 14, 2010 | 11:26 AM
  #31
sharrack's Avatar
Message for Mt. Goat
Hey dude,
thanks for posting the bushing pics.
I've got mine in hand and I'm over at HD wondering what size plumbing caps to pic up.
I had the 2 " in my hand BUT my bushing head will not fit inside a 2" cap fitting.
I see a 2 stamped on the side of yours.
I have Toyota bushings.
It almost seems like I need something larger than 2 "
Is your runner a 99 ?
Thanks for the help.
Kenny S>
Old Jan 14, 2010 | 11:31 AM
  #32
mt_goat's Avatar
Hey dude,
Kenny S>
IIRC I used a grinder bit and a die grinder to slightly enlarge the opening. I have a 93 pickup.
Old Feb 1, 2010 | 04:14 PM
  #33
aowRS's Avatar
Any updates?
Andreas
Old Feb 1, 2010 | 09:42 PM
  #34
dntsdad's Avatar
Bummer. I have a parts 97 Runner here and I would have made you a great deal.
Old Feb 19, 2010 | 03:41 PM
  #35
sharrack's Avatar
I have no time to get involved with the removal and installation of the bushings.
Anyone know a shop in the Phoenix area that will press out and in the New
bushings?
Sonoran Steel said no dice.
Thanks , kenny s
Old Feb 19, 2010 | 04:35 PM
  #36
mt_goat's Avatar
bushings?
Thanks , kenny s
Might try ZUK.
http://www.gearinstalls.com/
Old Feb 20, 2010 | 02:15 PM
  #37
sharrack's Avatar
No go on that one but he recommended NAPA auto parts?
Geez.........wish I had one of those 150.00 presses the guys from north carolina used to sell out of the back of pick up trucks in NY !
Kenny S>
Old Feb 20, 2010 | 02:19 PM
  #38
sharrack's Avatar
ha ha ...........a 6 ton press is 89.00 at harbor freight !
Old Feb 20, 2010 | 04:57 PM
  #39
mt_goat's Avatar
How about just a big vise?
voiddweller
19
May 2, 2016 09:10 PM
alfonz33
9
Nov 16, 2015 09:21 AM
Niameyrider
Jun 25, 2015 05:50 AM
ranma21
Jun 22, 2015 11:55 AM
2wdtundra
Jun 17, 2015 01:41 AM
