99 4Runner 2WD V6 Rough Idle When Warm Only
Old Feb 17, 2014 | 07:38 AM
Zach99SR5's Avatar
I have a 1999 4Runner 2wd V6; Rough idle, only when Warm. Cold idle has no problems (live in LA so, Cool odle!)... OBD read 0300 and 0301, multille misfire and misfire cylinder#1. I am still having the rough idle after doing all of the following:
Replace Cyl#1 Coil, wireset and all 6 plugs. Improved all around performance, but not the idle issue.
Then Replaced PCV Valve and thoroughly cleaned MAF sensor, Idle Air Control (IAC) Valve, intake hoses and Throttle body. Truck running GREAT, but still have the rough idle when warm. I dont have any way of testing the new coil...
Could I have a BAD, New, Coil? Or what should attempt next? Fuel injector and new IAC valve are a little expensive to NOT be sure of a fix.
Old Feb 17, 2014 | 08:27 AM
DRCOFFEE's Avatar
I had a similar issue in my 99 SR5. At first it cold idled fine but as soon as it reached op temp it stumble and idled rough. But it progressed to poor driving and then limp mode. My problem turned out to be a bad fuel inject #4. I swapped out all three on the drivers side #2, 4, 6 at the same time because it was such a bitch to get to. I can do the others without removing the intake at a later date. I had code P304
As it was explained to me, as the engine heats up the electric coil inside the injector separates and breaks the connection to control the injector signal.
Old Feb 17, 2014 | 08:27 PM
Zach99SR5's Avatar
That makes a lot of sense, but costs A LOT MORE CENTS!
I was hoping to avoid replacing fuel injectors, but that may be the only option.
Anybody know a way to test a fuel injector?
Going thru all the other steps has the truck running Beautifully otherwise!
Old Feb 19, 2014 | 07:35 PM
DeathCougar's Avatar
This man has it right
Old Feb 19, 2014 | 07:58 PM
Zach99SR5's Avatar
Ok, I am starting to buy tools to keep doing stuff on my own. Recommendations for an injector tester and compression test system?
Old Feb 19, 2014 | 07:59 PM
Zach99SR5's Avatar
RockAuto has some Reman. plugs for only $40-$50. What brand should I use for injectors if they tend to go bad on 4runners? Remanufactured or NEW?
Old Feb 20, 2014 | 03:39 AM
DRCOFFEE's Avatar
The GB reman fuel injectors have been great. They were only $30 each. Be sure to get the correct colored injector. There is no way to test the injectors on the truck. If the coil is broken, you may get good resistance cold but then zero when hot. Its going to be intermitant. Considering the time to R&R the injector, its smart to replace them all at the same time. That way they are all new and balanced. Dont forget to twist the injector before pulling them out and lubing the o-rings before installing the new ones.
Old Feb 20, 2014 | 06:16 AM
Zach99SR5's Avatar
Thanks. Any engine grease will do for lube or should i use a particular kind for the injectors?
Old Feb 20, 2014 | 06:21 AM
DRCOFFEE's Avatar
Vaseline works fine. You dont want to use anything that will degrade the o-rings.
Old Feb 20, 2014 | 06:32 AM
Zach99SR5's Avatar
Good to know. Can I do that with more that just the injector rings?
Old Feb 20, 2014 | 06:49 AM
DRCOFFEE's Avatar
What do you mean?
Old Feb 20, 2014 | 06:55 AM
Zach99SR5's Avatar
I just mean as a lubricant for different gaskets. For example, I need to change Trans filter/gasket soon. Just lube with Trans fluid or something like vasoline?
Old Feb 20, 2014 | 07:12 AM
DRCOFFEE's Avatar
use the fluid you are replacing in that case.
Old Feb 20, 2014 | 07:38 AM
Zach99SR5's Avatar
Thanks.
Old Feb 22, 2014 | 02:47 AM
Zach99SR5's Avatar
I bought an OBDII scanner for $25, have 1 new OEM injector (for now) on the way to change out from Cyl#1. Scanner is only showing P0301 now, No P0300.
I am going to test the new Coil and Plug that I put on Cyl#1 before changing the injector.
I will check back in a few days when I get this done!
Old Feb 27, 2014 | 04:19 PM
Zach99SR5's Avatar
New injector in Cyl#1 fixed my problem!
Now this 99 is like a new truck! New plugs & Cleaning out the throttle body and IAC really made a huge difference!
Old Feb 27, 2014 | 04:24 PM
DRCOFFEE's Avatar
Its a good feeling to fix the truck affordably and learn something along the way. Kudos
Old Feb 27, 2014 | 04:35 PM
Zach99SR5's Avatar
I appreciate the help and Yeah it is! Haha
Longbed 90
Mar 11, 2019 12:38 PM
Chicken12
Oct 14, 2015 03:54 PM
Yont283
Sep 20, 2015 10:56 PM
Yont283
Sep 12, 2015 10:03 AM
noahstancik
Sep 10, 2015 10:47 AM
