98 intake silencer removal mod
Old Mar 16, 2007 | 09:00 AM
jrock's Avatar
anyone do this mod? I acquired the parts from a 99 runner to retrofit my 98. the hole on the 99 intake piece-where a black hose connects into is slightly wider than the tube-and wider than the 98 stock tubes-hole. Not sure if I need to make a PVC connector deale-o. bobs write up in the tech-performance forum did not bring this up.
thanks.
Old Mar 16, 2007 | 10:08 AM
Elton's Avatar
the 99 one looks a little hard i just went with my 98 one and used some plumbing caps as in the writeup its been working great and is really easy to do
Old Mar 16, 2007 | 10:12 AM
04 Rocko Taco's Avatar
I also would stick with the 98 ISR.
here is a CHEAP write up also. Much like Eltons, only a little different parts. This is off an 04 taco.
https://www.yotatech.com/forums/f2/newly-designed-isr-04-double-cab-100417/
Old Mar 16, 2007 | 10:14 AM
Elton's Avatar
also heres a write up https://www.yotatech.com/forums/f130/intake-silencer-removal-mod-installation-96-97-3-4l-engines-74837/
Old Mar 16, 2007 | 03:09 PM
BMWToyotaMan's Avatar
Just find a 3 inch mandrel bent pipe 45 degree angle, cut the boot and get some hose clamps. It will do better then just plugging the large openings.
Blamalam
Mar 12, 2022 07:34 AM
priest16
15
Aug 6, 2015 07:43 AM
Flossy
Aug 5, 2015 05:14 PM
Massmayhem247
Jul 18, 2015 05:46 AM
